TT2 runout problem - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 28th, 06, 02:13 PM Thread Starter
Noel
TT2 runout problem
Looking for some input from some of the tire guys here. I have had a frontend vibration I can't get rid of. I had the set roadforce balanced and they told me the fronts were out of spec. I am going to be sending a couple of rims back to American racing. They told me their tolerance for out of round is .035". Any thoughts on the specs I have here? Would this cause a fairly bad vibration? Worse above 75 mph. They are 17" on 245/45's and 275/40's
Thanks Noel
Front Rims
1. Inner Outer
Lateral .026 .040
Radial .024 .018
2.
Lateral .029 .025
Radial .050 .022
Rear Rims
1.
Lateral .019 .034
Radial .020 .013
2.
Lateral .009 .011
Radial .011 .017
Noel
Tornado Red '69 Camaro ZZ383, 700R4, LS1 brakes, 17" TTII's
noels69 is offline
post #2 of 2 (permalink) Old Feb 6th, 06, 10:25 PM
Re: TT2 runout problem
Yeah, .035 might not seem like alot, it's about the distance of a spark plug gap. I imagine it would cause major vibration above 70 MPH. I used to balance tires for a living, and any rim that required more than 3 ounces of weight, would be considered out of round. So it doesn't take alot to throw them off.
Camaro buds until the end!!!
Camaro Dave is offline
