15 x 7 4" bs 235/60 or 225/60? - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 31st, 06, 01:38 AM Thread Starter
I'm currently have 235/60/14's on 14x7 with 4 1/4" bs in the front. This set up has worked flawlessly in my 68 RS/SS BB with 69 disc and original springs. The new wheels I'm considering are 15x7 w/4" bs (machined alloy, no custom bs available). I'm not sure if a 235/60 will work flawlessly, I'm fairly sure a 225/60 will. Is a 225/60 noticably smaller/narrower then a 235/60? Any thoughts or suggestions? Thanks. Mike
Mikr55 is offline
post #2 of 2 (permalink) Old Jan 31st, 06, 01:39 PM
Re: 15 x 7 4" bs 235/60 or 225/60?
a 225 will have 1 cm narrower tread and be .6 cm shorter than a 235
but you are going 1" taller on the rims and keeping the same series (height) tires, so the tire sizes you have listed will be much taller than the old ones
go to www.tirerack.com and look up the specs for tire sizes and you may find that you want to go with a shorter tire
400bird is offline
