86 Monte SS Wheels - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 6th, 06, 12:40 AM Thread Starter
Lindsay
86 Monte SS Wheels
Also same as 80-81 z28 with alumninum wheels. Lug nuts seem to be special and metric size to boot. Anyone know if a 7/16 lug nut is made to fit these wheels? Want to mount on older chevelle.
68 RS/SS 396 now 496 CID
601 H.P. 601 ft/lbs. torque
Yes, I have the Dyno Sheet!
Muncie 4spd.
4.11 12 bolt
MREMCHN is offline
post #2 of 5 (permalink) Old Feb 6th, 06, 04:01 AM
Re: 86 Monte SS Wheels
No, they are not. You will have to get the lug nuts with the correct taper and SAE thread. Summit and Jegs should have them. Ask the sellsperson.
post #3 of 5 (permalink) Old Feb 6th, 06, 07:30 PM
Actually you can (or last I check'd) still get them from GM, I *think* Classic Industries also stocks 'em. The wheels are called N90's (also a designation on another aluminum Z28 wheel so be careful). If you pick the the lugs up make sure they are the early 7/16 lugs from the Z28 and you'll be fine... I think GM had 'em priced at about $4 a lug though (maybe a bit less but it was a shock when I last looked). I'd also check Ebay, maybe someone has 'em used and cheap! The proper lugs are a must with those wheels.
radial72 is offline
post #4 of 5 (permalink) Old Feb 8th, 06, 06:30 AM Thread Starter
Lindsay
Thanks! Found some somewhat local, but wouldn't have without your guy's information!
Muncie 4spd.
4.11 12 bolt
MREMCHN is offline
post #5 of 5 (permalink) Old Feb 8th, 06, 06:15 PM
BonzoHansen's Avatar
Acorn seats. Go get them at your local auto parts store.
TC Member #13
BonzoHansen is offline
