What size wheels and tires? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 6th, 06, 09:24 AM Thread Starter
I have a 67 Camaro, I would like to go with some 16" American Racing Trakstar S wheels. I want to go as wide as possible in the rear, but stay within the wheel wells. I have Global West tubular A-Arms up front with the QA1 coil over setup. What size wheels and tires, backspacing ...etc??
Thanks!
HaulnSS is offline
post #2 of 3 (permalink) Old Feb 6th, 06, 12:34 PM
Re: What size wheels and tires?
the widest you can go in ther rear in 275 if you get the bs right
if you get a 9.5" wide rim with 5.5" bs thats about normal (rear)
and 8" wide rimewith 4.75" of bs (front)
but every car varies and if you have disc brakes it changes again
but you can not get 275s for a 16" rim, i recomend you step up to 17"
there are tons more tire choices for 17" rims than there are for 16" rims
400bird is offline
post #3 of 3 (permalink) Old Feb 7th, 06, 05:55 AM Thread Starter
Thank you, after reading alot more information on this board, I think I will probably go 17". Thanks for the info!
HaulnSS is offline
