17" TORQUE THRUST II for my 69' - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 15th, 06, 11:33 AM Thread Starter
jcs
can any of you guys tell me the most reliable sizing for front and back 17" TT w/tire sizes. i have been told 17x8 up front 17x9.5 out back. don't know what offset or tire size. i want to fill up as much of those wheel wells as possible but i don't want any wheel rubbing problems. any help from you gentlmen would be appreciated. thanks,jim........
jcs is offline
post #2 of 5 (permalink) Old Feb 15th, 06, 12:58 PM
Re: 17" TORQUE THRUST II for my 69'
If everything is perfect (rear end) they will work.......A safe beat that looks real good in my opinion is,
17X7 front 235/45 4.0 B/S
17X8 rear 255/45 4.75 b/s
No rubbing and good looks..........My 2 cents...D
69z302 is offline
post #3 of 5 (permalink) Old Feb 15th, 06, 01:48 PM
Robert
front 17x8 4.75bs 235/45/17 2" drop
rear 17x9.5 5.5bs 255/45/17 1.5" drop
I had a slight rub on the inside left rear when turning in some driveways. A 1/4" spacer fixed it. There's plenty of guys here running the same setup without any issues. If the car is not lowered you may want to consider a little taller tire in the rear, maybe a 50 series.
Robert
TC member #18
rojo is offline
post #4 of 5 (permalink) Old Feb 15th, 06, 10:39 PM
I have the same rear wheel as ROJO, with 275/40s and 3'' drop springs. No rubs.
yellowrallys is offline
post #5 of 5 (permalink) Old Feb 18th, 06, 02:16 PM
You are right with the 17 by 8 and 17 by 9.5 in back that is what I am running on my 69 but used the the Coddington brand.
lchb7 is offline
