calling all wheel/tire gods!! - Team Camaro Tech
post #1 of 18 (permalink) Old Feb 16th, 06, 02:11 PM Thread Starter
Armando
tejasrs/ss's Avatar
Ok fellas..here's the situation...could someone tell me PLEASE what is the ideal size and most importantly the backspacing I will need to get some 17's under my 67 RS/SS. First I should tell you what mods have been made or will be by the time the car hits the road...
Hotchkis TVS System which will...
lower front end 2 inches
lower rear end 1 1/2
Baer Track 13" rotors in front and 12" Sports in the back. I called Baer about the differences in the backspacing and they told me that their system will quote "narrow it by 1/8" on each side" I have no idea what he meant and he couldn't explain it either! I'm hoping someone has added Baer brakes and can tell me what they experienced.
OK THIS IS WHAT I'M HOPING I CAN DO
Front 17x7 (what backspacing and what size tire?)
Rear 17x8 (what backspacing and what size tire?)
OR can I go with a 17x8 in the front and 17x9 or 9.5 in the rear and what backspacing there?? I don't want to mini-tub and I'd rather not mess with rolling no fender lips either.
Sorry for the long post but my wife said I could use the income tax money to buy my wheel/tire combo and I want to do all my research before she changes her mind!! HA HA
Armando
1967 Chevy Camaro RS/SS
2012 Ford F150 Supercrew FX4
2007 Ford Mustang GT/CS (sold)
2002 F150 Harley Davidson (sold)
tejasrs/ss is offline
post #2 of 18 (permalink) Old Feb 16th, 06, 06:09 PM
Re: calling all wheel/tire gods!!
For a comforatable fit, 225/45 on a 7 w/4" backspace in front, 255/45 on an 8 w/4.5" bs in back.
Bigger can work too, but I never suggest it, if you want bigger, do some measuring.
post #3 of 18 (permalink) Old Feb 16th, 06, 07:22 PM
Armando,
I have a 68 Camaro with the exact same brake set-up as you. I went with 17 x 8 wheels with a 4.75" backspace on all four corners. Front tires are 245/45/17 and rear tires are 255/45/17. I do get some rubbing on the fronts when I hit a large dip in the road, but nothing that damages the tires. A 235/45/17 would have probably fit better, but I am still happy with the 245's. I think most guys are using somewhere between 4.75" and 5.0" backspace on the front. My car has 2" lowering springs in the front and 3" lowering springs in the rear.
On the rear you may be able to go with a 275/40/17 on a 17 x 9.5 wheel with 5.5" backspace. I have read about several guys with that size wheel on first gen camaros that report no to minimal rubbing issues.
As far as the Baer brakes, I was told it would increase the wheel backspace requirements by about 1/4" when switching from the stock drum brakes.
Woody68 is offline
post #4 of 18 (permalink) Old Feb 17th, 06, 08:43 AM
I am running 225/45/17 on 7" with 4" backspacing and 255/45/17 on 8" with 4.75" backspacing.
I have a 2" drop in the front and I dearched the rear springs 1 and 1/2".
I will post some pictures with the front clip on this Sunday.
I am actually going to start it for the first time (hopefully) Saturday.
jhilts is offline
post #5 of 18 (permalink) Old Feb 17th, 06, 10:31 AM Thread Starter
Armando
tejasrs/ss's Avatar
thanks for the info guys. Yea pics would be great! Woody68..are you running your stock a-arms to go with the 4.75 backspacing in the front?
Also does anyone have a pic of a 17x9.5 wheel in the rear of a 67-68 Camaro? I would love to go that wide if possible. Also let me know what the backspacing is! Thanks!
Armando
post #6 of 18 (permalink) Old Feb 17th, 06, 11:11 AM
I am running DSE upper and lower tubular control arms. Here is a picture of my car.
http://img114.imageshack.us/my.php?image=dsc00308lp.jpg
Woody68 is offline
post #7 of 18 (permalink) Old Feb 17th, 06, 11:46 AM Thread Starter
Armando
tejasrs/ss's Avatar
AHHH..I wonder if that allows you to use the added backspace?? I'll be running my stock upper and lower a-arms
Armando
post #8 of 18 (permalink) Old Feb 17th, 06, 04:15 PM
Woody,
I'm almost done with my DSE setup and ready to order wheels also...would 5" BS work better up front?
His and Hers Marina blue 67's
67FamilyFun is offline
post #9 of 18 (permalink) Old Feb 17th, 06, 04:42 PM
Originally Posted by 67FamilyFun
Woody,
On my car, I think that 5" BS would have been a little better. I do not have any problems with the wheels hitting the frame with the 4.75" BS and think that the additional .25" BS would be better. If you get too much BS you may run into problems with your wheels hitting the frame at full lock. However, you can always use a spacer to move the wheels out some. You don't have that option if you get a wheel with too little backspace.
Woody68 is offline
post #10 of 18 (permalink) Old Feb 18th, 06, 02:51 PM
Carl
Check my website for tire/wheel info.
CarlC is offline
post #11 of 18 (permalink) Old Feb 18th, 06, 03:33 PM Thread Starter
Armando
tejasrs/ss's Avatar
Thanks Carl but you aren't using the stock A-arms on your car. Nice car BTW! But without folding fender lips and changing the a-arms to aftermarket, what is the maximum width I can go on the front and rear of my car?
I'm beginning to think I that the best I can do is 17x7 up front and 17x8 in the rear just to be on the safe side???
jhilts...I'm looking forward to seeing pics of your ride~! thanks
Armando
post #12 of 18 (permalink) Old Feb 18th, 06, 03:56 PM
Jason
jay'srs/ss's Avatar
tejars/ss,
I haven't got my car back from getting all my stuff installed. I'm picking it up on Monday, i can't wait!
So we've got the same brake & suspension set up, except i got Speedtech Tubular A Arms Top & Bottom. I mounted my wheels on before i took it to the shop. 17x7 4.75 BS & 17x8 5.5 BS for the rims with 225/45/17 & 255/45/17 tires. Before everything got put on, i could barley fit my fingure between the tire and the inner fender front & back. After my brakes went on, i could easily fit my fingure between the tire and body. So the discs are wider than the drum brakes were. So much in fact that i had to get longer wheel studs.
So i think 17x7 4.5 BS & 17x8 5.25 BS would be real safe. I don't think i'll have any problem with the way i've got my car set up. I'll let you know when i pick up my car if it's okay.
My Cars:
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
SOLD!!!
88 Camaro IROC-Z SOLD!!!
SOLD!!!
jay'srs/ss is offline
post #13 of 18 (permalink) Old Feb 18th, 06, 09:54 PM
im not a safe kinda wheel guy , i like to stretch it a bit so ill tell you what i did. i did a lot of measuring and went with your same brake package (baer) and went 285/40/17 rear with 5.34 bs and 245/45/170front with 5.00 bs 17/9.5 rear and 17/8.00 front , its tight but looks kill. little fenderwell lip massage.. fits fine and thats with 2"" drop on all corners. remember baers rotor will extend your fronts out by1/8 inch. your tire sidewall bulge measurments dont really extend past a larger diameter rim so your safe to use a larger wheel IMO. i was using 15x 8.5 with 275/50/15 prior on rear with 4/7.8 bs but the side wall bulge is just about the same as the 17'' combo (measurement wise ) my car is a68 for ref,,,
dougs68ss is offline
post #14 of 18 (permalink) Old Feb 19th, 06, 05:33 PM Thread Starter
Armando
tejasrs/ss's Avatar
Originally Posted by jay'srs/ss
tejars/ss,
hey jay,
ok buddy, except for the tubular a-arms of yours we pretty much have the same suspension. I look forward to seeing fresh pics of your ride!!
Armando
post #15 of 18 (permalink) Old Feb 21st, 06, 07:14 PM Thread Starter
Armando
tejasrs/ss's Avatar
hey Doug..I'd love to see a pic of your tire wheel combo! I headed out tomorrow to order my new wheels!
Armando
