American Racing Wheels - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 30th, 06, 01:54 PM Thread Starter
I have a 68 Camaro, drum brakes, lifted 2 inches in the front and rear. I am planning on running 17x8 American Racing Tougue Thrust ll on a BF Goodrich G-Force TA 235/45R17 on the front. My question is what would be the backspacing to give the wheels an offset?, not concerned about rubbing on the top of the fenderwell only when I am turning, That old school look!
ogopogo is offline
post #2 of 6 (permalink) Old Jul 30th, 06, 05:45 PM
Harley D
HarleyD67's Avatar
Re: American Racing Wheels
4 1/2"-5" BS
I just ordered some AR's 17x7's with 4" BS 4 1/2" would have looked better, but not available.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #3 of 6 (permalink) Old Aug 11th, 06, 09:32 PM
Would this size 17" wheel fit on a 67-69 Camaro?
tire sizes
rear - P285/40ZR17
front - P275/40ZR17
Wheel sizes - 5x4.5 bolt pattern
Size 17x12
backspace 7 in
offset 1
front
size 17x10.5
backspace 6.25
offset 1
kz1000ltd is offline
post #4 of 6 (permalink) Old Aug 11th, 06, 10:40 PM
Harley D
HarleyD67's Avatar
I think the rear tire would fit, but I think the front is too big. 245 is about as big as I would go on a stock or lowered front end. I also think you've got too much back spacing on both the front and rear without modifying something. Are you running a 9" rear? 5x4.5" is a ford bolt pattern.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #5 of 6 (permalink) Old Aug 13th, 06, 12:17 PM
tire sizes
rear - P285/40ZR17
front - P275/40ZR17
Size 17x12
backspace 7 in
offset 1
front
size 17x10.5
backspace 6.25
offset 1
In short, no.
There is no way in hell you are gonna get a 12" wide rim out back, the biggest most guys go with is 9.5 i personally have a 10" rim but its a 19 so i have zero tire buldge.
Also for a stock sub a 10.5" wheel is way too wide hell even with the new dse sub you can only fit a 10" rim something like a 17x8 is more like it.
As for tires, a 285 wouldnt even fit on a 12" wide wheel first off. but id say go with a 275 out back and no bigger than a 245 in front.
There are dosens of guys with those exact sizes on first gens so do a little more research and your set.
And did you really lift your car 2" all around and are putting 17s on.... how exactly is that old school, more like semi-donk
jackalope is offline
post #6 of 6 (permalink) Old Aug 13th, 06, 02:33 PM
Thanks for the info, I believe they turned out to be Ford wheels anyway!
American Racing buys Boyd Codington jrager Bench Racing 33 May 27th, 06 04:23 PM
camaro wheel's in reply to NO MORE TORQUE THRUST'S RS3SDL2MG Wheels & Tires 26 Dec 24th, 05 07:21 AM
Water Spots on Weld Racing Wheels???! Procharged69 Wheels & Tires 3 May 19th, 03 08:19 AM
American Racing TT2 Jonas W Wheels & Tires 1 Feb 25th, 02 10:21 PM
'87 IROC wheels on '89 Firebird gjacobs Wheels & Tires 1 Jun 7th, 01 02:19 AM
