Will these fit my 69 camaro? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 4th, 06, 07:34 AM Thread Starter
Ted
Question Will these fit my 69 camaro?
I have a 69 camaro with monoleaf rear springs, disc brakes up front and drums in the back. Will this tire /wheel combo work without rubbing issues? Torque Thrust II 17x8 w/245/45zr17 98y, bs 4.5 up front. 17x9.5 275/40zr17 98y, bs 6 in the rear. the tires are BFGoodrich G Force t/a's. The bolt pattern is 5x4.75. These were on a 1970 442. Thanks.
tgifford5 is offline
post #2 of 6 (permalink) Old Aug 4th, 06, 08:09 PM
Re: Will these fit my 69 camaro?
I wouldn't take them unless you can try them before you buy them. Bottom line is they are not the perfered backspacing. An 8" wheel in the front needs 4.75 to 5" backspace. The rear needs 5.5 to 5.75" backspace. Even then there are cars that have minor rubbing issues. With those tire sizes the backspace needs to be just about perfect. I would pass on them unless you can trial fit them.
JV69z/28rs is offline
post #3 of 6 (permalink) Old Aug 5th, 06, 05:30 AM
Ditto!
pdq67
post #4 of 6 (permalink) Old Aug 5th, 06, 06:34 AM
Bob
I dont know what kind of set-ups you guys run in the rear,but my 69 camaro has a 15x8 weld wheel with a 4.5" backspacing and fits like a glove with a 28x10.5 M/T slick !!!! They even slightly rub the INSIDE when i take a turn too fast.
5.5" - 5.75" Backspacing on a '69.......HOW ?????
bob
Bgonz 69 is offline
post #5 of 6 (permalink) Old Aug 5th, 06, 01:13 PM
Chris
130fe's Avatar
Thumbs up Re: Will these fit my 69 camaro?
Bgonz69, they are refering to using a 8inch wheel up front and a 9.5inch wheel on the back when using that particular backspacing.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #6 of 6 (permalink) Old Aug 5th, 06, 03:14 PM
Bob
Lightbulb Re: Will these fit my 69 camaro?
OHHHHHHHH.....Now i get it !!! Maybe i should learn to read a little better !!!
SORRY GUYS......
But i told ya a 5.5" backspacing wont fit on the REAR.
bob
Bgonz 69 is offline
69 Camaro and a 454,what carb and manifold will fit stock cowl hood? 1320King Camaro Tech 4 Aug 9th, 06 08:24 AM
MAILBAG: Readers give reactions on Camaro OverAnxious Fifth Generation 0 May 18th, 06 07:07 AM
69 camaro will 15x10 with 5 1/2" BS fit stock body? NJTURBO Wheels & Tires 5 May 9th, 06 05:02 PM
what do i have to do to fit 245/50R16 on my 69 camaro importkiller69ss Wheels & Tires 4 Dec 8th, 05 07:40 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
