16" Rally Wheel with LS1 Brakes? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 7th, 06, 09:54 AM Thread Starter
Has anyone tried using the 16" Rally wheels with the LS1 brake conversion? I am running both the front and rear disc on my 68 and trying to decide on wheels. I really wanted to keep the stock look if at all possible. Any help would be greatly appreciated.
MSCHMIDT9090 is offline
post #2 of 6 (permalink) Old Aug 7th, 06, 02:01 PM
Andrew
Andrew69's Avatar
Re: 16" Rally Wheel with LS1 Brakes?
I bought a 16" ralley wheel from Summit to try, and it wouldn't fit over the 12" LS1 brakes on my car, so I sent it back for credit. Like you I wanted the stock look and had falsely assumed a 15" wheel would fit over a 12" rotor and caliper.
It seems they use the same center section as the 15" wheel, but just weld a larger rim around it. Another option you could consider would be a 16" billet aluminum wheel from Wheel Vintiques, I believe they would fit, but they are expensive. http://www.wheelvintiques.com/
I ended up selecting 16" Torque Thrust II wheel. 7" x 4" B/S front and 8" x 4.75" B/S rear. They clear the front calipers by about 1/4" in the radius and look like they were factory fit. They also look good on the car, click on the link in my signature to see photos.
From home I could send you a photo of two, if you like.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #3 of 6 (permalink) Old Nov 25th, 16, 05:53 PM
Ray
http://ls1tech.com/forums/chevrolet-...ro-swap-5.html
Found this thread on Ls1tech. This guy fit 6 piston willwood up front and 4 pistons in the rear with 12" rotors. I might order one to test fit just to confirm.
camarodude87 is offline
post #4 of 6 (permalink) Old Nov 25th, 16, 06:16 PM
Vega$69's Avatar
I suggest you go with 17" ralley wheel as 16" tire selection is very limited.
Vega$69 is offline
post #5 of 6 (permalink) Old Nov 25th, 16, 07:54 PM
Ray
I plan on it. WV doesn't have the size available now. Also thanks for the #. Will have to give him a ring once I get the wiring started.
post #6 of 6 (permalink) Old Nov 26th, 16, 11:05 AM
Rich
From what I have seen the Circle Racing Billet Wheels look the best and they have a lot of different sizes. Circle Racing Wheels
1967 SS350, Under construction.
H20cooled is offline
Can I use the 14" Rally Wheel Caps on 15" Wheels? POCKER Wheels & Tires 2 Jul 30th, 06 11:22 AM
Rally wheel derby caps SY1 Wheels & Tires 4 Jul 4th, 06 07:32 PM
how to change front wheel studs on drum brakes? 1Fast69chevy Wheels & Tires 3 Apr 25th, 05 03:30 PM
Which hub cap ornaments on '67 rally wheel with front disk-brakes? DL Wheels & Tires 1 Sep 25th, 03 12:00 PM
14x6 Rally rims and disc brakes Gulcher Wheels & Tires 6 Oct 21st, 01 06:18 PM
