would it make any difference (4" or 4.5" backspacing) - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 16th, 06, 07:02 PM Thread Starter
Hey guys here is my concern..
When I put set of 17 by 8 torq thrust wheels for the front with 245/45 tires , the tires started to rub against the fender lip too bad. I had to change the tires to 235/ 45 to solve the problem;however, they still rub.
I had to get a new set of stock springs to raise the car up to get rid of the rubbing problem and dragging of the long tube headers on small speed bumps. Now it is at the shop to put the new springs.
I contacted American Racing, and they recommend 4.5" backspacing for the front wheels. However, I found out that the wheel & Tire shop put the wheels with 4" backspacing, it would take weeks to order wheels with 4.5 " backspacing.
Since I am putting stock springs back in order to get the stock height, Is it still worth it to get a new set of front wheels with 4.5" backspacing instead of the 4" backspacing or it is not worth it?
Thanks guys
72-camaro
72-camaro is offline
post #2 of 6 (permalink) Old Aug 17th, 06, 07:42 PM
Re: would it make any difference (4" or 4.5" backspacing)
Sorry for the lack of response but the majority of info in this forum is on the 1st gens. I really do not know the correct backspace for your car but I would say that in my opinion yes a 1/2" could certainly mean the difference between rubbing and not rubbing. If a tire is rubbing on a sharp edge it could mean new tires or worse yet a tire failure while driving. Just not worth in my opinion - get the correct backspace but 1st find out what it should be. My guess would be that it could be like a 1st gen and a 4.75 on an 8' wheel may be even better. Good luck.
JV69z/28rs is offline
post #3 of 6 (permalink) Old Aug 18th, 06, 08:14 AM
Try MadMike's great Second Gen. site at SGCOG!
What is it guys? Nasty-Z-28.com??
I just type in SGCOG is all to get to it.
pdq67
post #4 of 6 (permalink) Old Aug 18th, 06, 05:00 PM Thread Starter
sorry did not know it was 1st gen forum, thank you jv69Z/28rs for the feedback. I know it is taking time to get a response.
I looked up the website, nastyz28.com, thanks pdq67.
post #5 of 6 (permalink) Old Aug 22nd, 06, 05:11 PM
hey guys, I have a 67 model. Using 17x7 on front 17x8 on rear. What size tires can I use without rubbing?
hotrodpreacherman is offline
post #6 of 6 (permalink) Old Aug 22nd, 06, 05:40 PM
This is oe fine 72 Z/28 with 245/ 17 5 4.75
dukeme is offline
K & N Filter make a difference zuma Tech 2002 20 May 15th, 05 11:44 AM
1 inch spacer make a difference? 1968camaro123 Performance 6 Feb 7th, 05 07:23 AM
4" Speakers for dash - Make?? dschribs Interiors 3 Feb 26th, 04 04:55 PM
4.5 backspacing? awsm69 Wheels & Tires 3 Feb 21st, 02 03:13 PM
Performance Drum shoes? Do they make a big difference? backfire Brakes, Suspension & Steering 8 Apr 3rd, 01 05:18 PM
