Foose Nitrous - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 24th, 06, 07:50 AM Thread Starter
Foose Nitrous
I WANT TO PUT 20X10 IN THE REAR AND 20X8.5 IN THE FRONT OF MY 69 CAMARO SS CAN ANYONE TELL ME IF THEY HAVE DONE THIS OR IF THEY FIT THANKS
ray_cvzs is offline
post #2 of 7 (permalink) Old Aug 24th, 06, 06:14 PM
Re: Foose Nitrous
I doubt it! How low is the car? If it is lowered 3" or more I think you are going get rubbing front and rear. The front 1st - an 8.5 wheel will work in the front with a backspacing of about 5 1/4 plus or minus an 1/8" with a 245 tire but I think a 245/35-20 will be way too tall. I think someone makes a 225/30-20 but then there is NO sidewall. I know for a fact a 235/35-19 on an 8" with a 4.75 to 5" backspace will work. Now the rear a 10" wide rear wheel almost always causes rubbing in the rear without rolling the outter lip and beating in the inner wheel well in the top of the tire area. You need a backspace of about 5.75 with the 10' wheel. What tire do you want to run? A 255/35-20 would probably fit without to big a deal but the tire will be stretched on that wheel. A 275/35 may work with minor rubbing after rolling lips and inner fender pounding. There are odd sizes also in 265 widths and there is the 285/30 also. How much rubbing are you willing to live with? If the car is low and you want to drive it and people are going to ride in with you I would advise you to either be preparred to work at getting them to fit or backoff a little on the sizes. Common choise is 18x8 with a 225/40-18 and 20x8.5 with a 255/35 tire. That works - several people have done it - no rubbing issues - bigger can be made to work but be prepared for alterations.
JV69z/28rs is offline
post #3 of 7 (permalink) Old Aug 24th, 06, 07:14 PM Thread Starter
Re: Foose Nitrous
so a 20x8.5 will work in front and back with a 255 35 20
ray_cvzs is offline
post #4 of 7 (permalink) Old Aug 24th, 06, 08:28 PM
Re: Foose Nitrous
The 255/35-20 is 27" tall - I doubt that tire is going to work in the front - It's been done (27" tall but a 255/45-18 tire) but I have only seen it once and it looked very very tight because of the height. It was close on top and at the edges in the front and rear. The 225/30-20 will probably fit and it falls within the reccommended rim width but there is no side wall - the tire is only 25.5" tall - so the sidewall is only 2.75" tall - less about a 1/2" for the wheel and you have about 2" from the wheel to the ground. That's not enough for me but you need to decide if that's the look you want. I would drop back an inch or two in wheel diameter but that's up to you.
post #5 of 7 (permalink) Old Aug 24th, 06, 09:37 PM
Re: Foose Nitrous
the foose nitrous wheel only comes in i think 4.5 inch backspace but if you were to add disc brakes that gives you another half inch therefore making it five inch b/s.
impreza13 is offline
post #6 of 7 (permalink) Old Sep 7th, 06, 05:26 PM
Re: Foose Nitrous
The Foose wheels are junk,A freind of as a set of nitrous wheels and the chrome plating is flaking off.they are made in china,go figure,not even made by Foose
rocket22 is offline
post #7 of 7 (permalink) Old Sep 11th, 06, 10:28 AM
Matt Jones
Re: Foose Nitrous
So your friend had one set of bad wheels, which makes them all junk?
Isn't that a bit of a blanket statement?
BTW, Foose is a designer, not a manufacturer.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
Wanted: Pics of foose nitrous II wheels on a 69 camaro darthvegagt Wheels & Tires 1 Jun 14th, 06 06:40 AM
Foose nitrous fit camrod67 Wheels & Tires 3 Jun 5th, 06 08:34 PM
First nitrous pass Yellow68SS Performance 15 Jul 9th, 05 09:37 AM
nitrous woes Ed Bleich Performance 25 May 10th, 03 10:40 AM
Did nitrous kill my motor? rlrr Troubleshooting 9 Nov 14th, 00 11:25 AM
