New rear wheels - Team Camaro Tech
post #1 of 1 (permalink) Old Aug 31st, 06, 08:31 AM Thread Starter
New rear wheels
I have 15X8 Weld draglites on my 67 Camaro.
The car has a real hook problem as it is a BBC. With street radials, it just fries the tires right off.
I'm willing to buy some wider rims and I know I need a DOT slick or a ET drag radial.
I currently have a P275 60R15's in the rear. At 7k rpm, I'm around 115. As noted above, I have no hook and subsequently I'm into 2nd gear before 60'. Its a TH400.
I run no line lock or trans brake. I just hold the break and when I get the light, I stab the throttle. I have to feather quite a bit to nurse some sort of launch. My 60' times are about 2.6 to 2.7. It has 4:88 gears.
So:
Obviously I'd like to hook better.
I'd like to get a little more mph at the end, I was hoping another inch of tire height could help.
Also, I'm wondering what you guys would do about width. Would you stay with an 8" rim or go wider?
If wider, what sort of backspace should I ask for? Its all stock in the rear. No tubbing or fender flares at all. It has single leafs and 70/30 adjustable shocks.
mkpatrick is offline
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
To replace rear leaf springs, can't I just leave the rear wheels on the ground? ggkeller Brakes, Suspension & Steering 6 Jun 13th, 05 10:24 AM
Rear discs, 8.2 10 bolt, 14" Rallye Wheels BPOS Brakes, Suspension & Steering 2 May 26th, 04 10:37 AM
1968 door alignment Steve W Body Shop 5 Sep 9th, 03 04:15 PM
Never ending spacing problem tl757 Body Shop 6 Jan 26th, 02 08:56 AM
