Cragar S/S wheel reccomendation for '67 Camaro??? - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 4th, 06, 08:03 PM Thread Starter
I'm putting a set of Cragar S/S wheels on my '67 Z-28 and wanted to hear from those who have found a good size to run without having to add air shocks etc. I'll be running 15's all around with radials and would like both wheel and tire size reccomendations please. Back in the day, 15 x 6 on the front and 15 x8's on the rear were the way to go, but they sometimes rubbed on the rear quarter panel and I don't want that! Any reccos??? Thanks, Mark
1965 Electra-Glide FLH
1990 Fat Boy - 6,200 miles
Previous: 9 '67 Z-28's, '67 L78, '67 Canadian Festival Car, and about 30 other '67 Camaros!
Zedder is offline
post #2 of 10 (permalink) Old Sep 4th, 06, 08:35 PM
AJ
Re: Cragar S/S wheel reccomendation for '67 Camaro???
i have 15x8 rims with p255/60r and they rubbed until i got the shocks rebent.
ace's68 is offline
post #3 of 10 (permalink) Old Sep 5th, 06, 06:24 AM Thread Starter
Thanks Ace's...I don't want to modify anything on the car, so that size isn't going to work on my car. Any other suggestions guys???
Zedder is offline
post #4 of 10 (permalink) Old Sep 5th, 06, 06:42 AM
First note is that the 15" cragars are still the old "unilug" one size fits all style lugnuts. This is not the best setup in the world. I would recommend you go with 16"s
The new larger size cragars are single bolt pattern with 45 degree seat conicle lugs, much better as far as accurately locating the wheel and minimizing side to side and up and down runout.
As far as sizes that are a comfortable fit on a 67-68, 4" bs on a 7" wheel in front, with a short 225 tire. 4.5" bs on an 8" rim with a 255 tires in back.
post #5 of 10 (permalink) Old Sep 5th, 06, 06:50 AM
67 Convertible's Avatar
I have the unilug Cragers on my '67. 15x7's all around, BFG's 215x60 on front, 245x60 on rear. No rubbing issues whatsoever.
'67 Marina Blue Convertible. L30, PG. All numbers match, 41k original miles.
"The only time you have too much fuel, is when you're on fire"
67 Convertible is offline
post #6 of 10 (permalink) Old Sep 5th, 06, 08:37 AM Thread Starter
Thanks guys. I'm definitely sticking with 15 inch wheels as I want it to look like the cars I had back in the '70's. '67 coververtible: Do you know what your back spacing is on your wheels? Do you have front disc brakes? Any other reccos guys?
Zedder is offline
post #7 of 10 (permalink) Old Sep 5th, 06, 09:38 AM
Zedder: Manual drum brakes all around, stock suspension. I'm pretty sure the Cragar backspace is 4 1/8 ?
post #8 of 10 (permalink) Old Sep 7th, 06, 06:41 AM
Imho, whatever the equiv. modern tires are that were E- and G-60's back then.
To me, just the right big-n-little look..
And a 7" rim with a stock, like 3.50" or 3.75" back-spacing will probably rub the top chrome edge at full droop! Therefore get a front rim that has a front-spacing that is LIKE STOCK!!!
How do I know??????????
And remember that our old cars generally don't sit the same side to side b/c mine never has! I use my old "finger" method by just sticking a couple of fingers between the tire roll and the top of the wheel well lips on cars to check and it seems like almost all of them are off some!!
Try it and you will see what I mean....
pdq67
post #9 of 10 (permalink) Old Sep 7th, 06, 04:32 PM
Check these out. I have them on my 69 vert. http://cgi.ebay.com/ebaymotors/Craga...spagenameZWDVW
ss dave is offline
post #10 of 10 (permalink) Old Sep 8th, 06, 04:17 PM
hope this works http://www.pro-touring.com/forum/att...4&d=1141840052 that copy/paste thing worked yea!
ss dave is offline
69 Right Front Wheel Well - Removing from assembled Camaro?? CamarosRus Body Shop 12 Mar 5th, 06 05:27 PM
1967 camaro wood wheel hub 67-L78 Camaro Tech 4 Feb 28th, 06 02:37 PM
Rear wheel brake problem, not a camaro ray moore Brakes, Suspension & Steering 2 Nov 6th, 05 06:11 PM
68 camaro steering wheel [email protected] Interiors 8 May 13th, 05 06:45 AM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 07:37 AM
