tire tubes in slicks? - Team Camaro Tech
post #1 of 9 (permalink) Old Sep 8th, 06, 06:12 AM Thread Starter
Jeff
with a set of m/t et drag slicks, do you have to use thier tubes? or will any proper sized tire tube work ? thanks
1967 Camaro, 468cid, 530 Hp, 515 ftlbstourque, 9 inch w/4.11 gears,detriot locker, 4 wheel disc brakes, th400
Jeff22 is offline
post #2 of 9 (permalink) Old Sep 8th, 06, 06:43 AM
Frank
Send a message via MSN to jet_car2000
Re: tire tubes in slicks?
Jeff use racing tubes only,, others are too thin and they will pinch and leak
jet_car2000 is offline
post #3 of 9 (permalink) Old Sep 8th, 06, 06:52 AM Thread Starter
Jeff
thanks
Jeff22 is offline
post #4 of 9 (permalink) Old Sep 8th, 06, 07:36 AM
Frank
Jeff i have seen guys use the regular tubes in the past but they allways seemed to get a hole in them,, compare them to a racing tube and you will see why.
Frank
post #5 of 9 (permalink) Old Sep 8th, 06, 07:16 PM
Dan
I ran m/t et drag slicks for a couple years, no tubes, no problems. Regardless, you may want to mark your tire to rim with a paint marker in one spot to watch for and slip between the tire and rim-- I've had them move, typically on the first day of running, then rebalance the tire if it moves significantly. It seems like once the tire gets hot and cools a few times, it doesn't slip anymore. Sorry if I got side-tracked. -Dan
62 Corvette (Stock Restoration)
68 RS/SS Camaro, LS7/T56
68 RS Convertible project LS3/480/4L70
2006 Corvette Z06
2011 Corvette GS Convertible
68sixspeed is offline
post #6 of 9 (permalink) Old Sep 8th, 06, 08:01 PM
Use the drag tubes and apply some talc powder in the tire with the tube. Keeps things from getting pinched .
TC # 349
zdld17 is offline
post #7 of 9 (permalink) Old Sep 8th, 06, 08:54 PM
I would also recommend running tubes in the front if you run narrow front tires and rims.
They'll probably go flat if you don't.
Stewart G. Griffin is offline
post #8 of 9 (permalink) Old Sep 8th, 06, 10:29 PM
I suggest rim screws too! Why not? Might as well go all out, I never have a problem with my tires/tubes/screws....
...forgot to put my story up....bout 3 years ago a fox body mustang I was racing (who was SLIGHTLY ) infront of me swirved into my lane with a flat tire...I slammed on the brakes and we almost collided (I was catching up ) upon later inspection...the tire spun on the rim, tearing the valve stem from the tube!!!
'67 Camaro in the works...
Newbomb is offline
post #9 of 9 (permalink) Old Sep 9th, 06, 10:30 AM
Frank
Yeap thats true the talc works good and the tubes dont stick to the tire or rim.
Frank
Driveline and Tire safety. Drag Fabricator Performance 17 Jul 5th, 06 03:35 PM
Tires Get An Expiration Date? BonzoHansen Bench Racing 46 Jun 7th, 05 08:17 PM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
Are tubes a must with street slicks? camaro-69ss Wheels & Tires 2 Jun 9th, 02 11:56 AM
