Oh! Gawd! Another rally wheel question!! - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 11th, 06, 08:44 PM Thread Starter
I just agreed to buying a '69Camaro. I want to put rally wheels on it. My question is can I get a 255/60r15 T/A Radial inside the rear fender when it's on a 15x8 with 4.5 bs? Would I need more back space? or is there not enough room for this size tire on a '69?
I think I have the front figured out.
215/70r15 on a 15x7 with 4.25 bs.
Fred
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 8 (permalink) Old Sep 11th, 06, 09:12 PM
Re: Oh! Gawd! Another rally wheel question!!
both will fit. you could go 225 in front if you want. your bs is right
post #3 of 8 (permalink) Old Sep 17th, 06, 08:23 AM Thread Starter
With the 4.5 bs will the 15x8 trim ring fit? I'm wondering if I will have to go to the 15x7 because of the non std offset.
Same question about the fronts. 4" seems to be std offset. If I go 4.125 will 15x7 rings fit or do I have to use 15x6 rings?
I'm trying to get this all figured out before spending the $$$ on mistakes.
Fred
__________
post #4 of 8 (permalink) Old Sep 17th, 06, 12:24 PM
"Tri-Tip"
Gary L's Avatar
I have 215/65R15 all around. 235/60R15 will rub on the front. When I got my car i had 235/60R14 on the front with no issues. Std Camaro BS.
Gary L is offline
post #5 of 8 (permalink) Old Sep 21st, 06, 10:57 PM
Johnny
the trim rings will work fine. I have 15x7 rings all around, even on my 15x8's on back.
67Camaro 396BB 750Holley, edlebrock performer,280isky,3.42 posi, turbo 350,stage 2 shift kit, 2800 stall, MSDready to run distributor, headers, 2.5"exhaust, Hotchkis(1.5"/2"drop).(orig.Deep water blue/light blue dlx inter, v8 column shift/bench seat)
johnny67 is offline
post #6 of 8 (permalink) Old Sep 22nd, 06, 07:33 AM
"the trim rings will work fine. I have 15x7 rings all around, even on my 15x8's on back."
Wow.
What springs are you running ?
"Cause you could fit a beagle between the tires and the fenderwells
markr is offline
post #7 of 8 (permalink) Old Sep 22nd, 06, 08:07 AM
Johnny
My mechanic had them re-arched, they are 5 leaf. I have been having problems with it but I almost have it figured out thanks to team camaro. Here is the thread.
https://www.camaros.net/forums/showthread.php?t=87917
johnny67 is offline
post #8 of 8 (permalink) Old Sep 26th, 06, 01:32 PM
Thanks.
Interesting thread.
markr is offline
Nightmare! Wheel Vintiques brand Rally Wheel - faninc Wheels & Tires 18 Oct 28th, 05 07:24 PM
68 camaro steering wheel question Willcap Interiors 2 Apr 28th, 05 10:52 AM
Original rear quarter wheel lips question 68Zgarage Restoration Corner 4 Jun 3rd, 04 02:58 AM
What is an A7 rally wheel from?? No 'E' in Camaro Tag Team 1 Jun 20th, 01 03:40 AM
Steering wheel and column question kausboy Tech 2000 1 Jun 5th, 01 09:36 AM
