69 coupe tires and wheels question - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 12th, 06, 06:42 AM Thread Starter
RJ
RJBaileyrn's Avatar
Hi guys, I have a 69 coupe that came with the following wheels and tires:
Front:
American Wheel-Torq-Thrust II 17X7 1/2, looks like about 4" backspace. M&S NT450, 225/50 R17 94V
Rear:
Torq-Thrust II 17X8, 4" backspace, M&S NT555 P245ZR17 89W
My back tires will bottom out on a big dip in the road occasionally, I have some air shocks back there that solve the problem without too much raising up, so it doesn't look rediculous.
The right front tire will rub on the wheel well lip with a left turn.
I wondered first if other guys have used this combo, and what problems if any they may have had. 2nd, is this setup too big for my car.
3rd, I wonder if this could just be a spring issue, since they appear to be original. I'm also going to be going to aluminum heads soon. Will that make much of a difference in front ride height?
I appreciate any and all comments and info from you guys. You are the best.
Thanks,
RJ
RJBaileyrn is offline
post #2 of 3 (permalink) Old Sep 12th, 06, 06:02 PM
Re: 69 coupe tires and wheels question
As far as I know American doesn't make a TTII in 7.5 wide. So the front is either a 7 or an 8 . 4" backspace is not enough. If it's a 7 it should be at least 4.25" or 4.5" if it's an 8 it should be 4.75" or 5.0". Backspace is the key with these cars! People are running 8.5 wide front wheels with 245 series tires on cars that are lowered 3" with no issues. In the rear up to a 9.5" wide wheel with a 5.5" to 5.75" backspace and up to a 275 series tire works on a lowered car. If you have to raise your car to stock height or higher you have the WRONG wheels! Do a search - we discuss this all the time. There is lots and lots of what fits and what doesn't info.
JV69z/28rs is offline
post #3 of 3 (permalink) Old Sep 13th, 06, 06:27 AM Thread Starter
RJ
RJBaileyrn's Avatar
Thanks for the info. I was sort of afraid that the backspace wasn't enough, but the fact that the right front tire is the biggest offender for rubbing made me wonder if the front springs were really weak. Having seem the sizes of tires and wheels people are running though makes me feel you are right about the backspace. Thanks much
rj
Wheels for my 69 camaro? ENP Wheels & Tires 2 Jun 13th, 06 08:20 PM
69 Camaro SS - 15" Wheels Question. PAV #227 Wheels & Tires 1 May 6th, 06 05:48 PM
Are stock 70-1/2 Z-28 wheels & tires rare? trplblk Wheels & Tires 14 Sep 9th, 05 06:03 PM
Question about selling mounted wheels and tires. RamJam Bench Racing 6 Jul 11th, 05 11:16 PM
Wheels and Tires for a 67 Camaro Coupe smitty20NH Wheels & Tires 1 Apr 11th, 02 09:21 AM
