rim hole correction??? - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 15th, 06, 05:20 AM Thread Starter
Red face rim hole correction???
I just got a real good deal on a pr of centerlines, however they have 4 holes on both sides of the lip where they screwed in for slicks. I want to run radials back on them, so does anybody have an easy cure. My though was to run self taping sheetmetal screws with some clear caulk. Any suggestions would be great, Thanks!
paperman is offline
post #2 of 4 (permalink) Old Sep 15th, 06, 08:03 AM
Re: rim hole correction???
The beads seal the holes so it is just a cosmetic thing to fill them up.
I would use short screws that fit, but don't go all the way through and calk like you mentioned to glue them in place and go.
pdq67
post #3 of 4 (permalink) Old Sep 15th, 06, 08:46 AM
Vintage 68's Avatar
Thumbs down Re: rim hole correction???
Originally Posted by paperman View Post
... though was to run self taping sheetmetal screws with some clear caulk. Any suggestions would be great, Thanks!
I would tap them out to the closest size to the existing hole then insert $$-Button-Socket-head-Cap-screws* into them to plug the holes.
Never know when that "clear caulk" would fail on you at speed and start throwing little sheet-metal screws all over the place
If it goes on a rotating part it's always best to bolt - not glue ...
note: * = these are small headed, allen drive stainless steel type bolts that look pretty nice when polished
Any good hardware or bolt supply house will have them.
1968 Convertible
Some trucks
Vintage 68 is offline
post #4 of 4 (permalink) Old Sep 16th, 06, 09:02 AM
Cool!
pdq67
RS Conversion on 1969 SS Coupe Camaro camaro350 Camaro Tech 31 May 13th, 07 07:57 PM
another fisher body specs question (body jig) morbid creations Body Shop 7 Jul 7th, 06 03:49 PM
Speedo firewall hole 68 RS 302 Electrical & Wiring 1 Mar 24th, 06 08:36 PM
Hole Size/Location in Firewall for Vacuum Hose Sid69Z's Restoration Corner 4 Jan 24th, 06 06:24 PM
Body mount hole location? BB69 Brakes, Suspension & Steering 3 Jun 30th, 04 02:25 AM
