69 wheels - Team Camaro Tech
post #1 of 3 (permalink) Old Sep 15th, 06, 05:56 PM Thread Starter
RJ
RJBaileyrn's Avatar
69 wheels
Hi guys, I have a 69 coupe and have had tire rub issues. I have determined thanks to you guys that I don't have enough back spacing. I have Torq-Thrust II's 17X7 on front and 17X8 on back. Looks like only 4 or 4.5 inch backspace.
From what I have read, it looks like I could run 8.5X17 with 4.75 backspacing and P245 series tires on the front, and 9.5X17 with 5.5-5.75 backspacing with P275 series tires on back. Is this going to be too tight? or am I pretty much assured of having enough room with these sizes??
If this is too tight, please suggest a size of 17" wheels and tires that will look good that I know will fit ok. Any help appreciated.
RJ
RJBaileyrn is offline
post #2 of 3 (permalink) Old Sep 15th, 06, 07:16 PM
Re: 69 wheels
1st you need to make sure your car is straight. Make sure you have the same amount of clearence on both sides of the car. Also the suspension and subframe bushings have to be in good shape. If not you may have rubbing issues no matter what advise we give you. If you are going with TTII's in the front 17x8 with 4.75 backspace and you can go with a 235/45-17 tire to have a little more room for error. In the rear a 17x9.5 with 5.5" of backspace. The 275 tire is tight back there and you may get minor rubbing on the inside crossing over some curb cuts. If you want to be safe you can go to a 255/45-17 tire. Some people here have done that. With that said keep in mind ride height and brakes can change these specs slightly. Also these cars are 35+ years old and some are more the worse for wear than others. Confused yet? You should be - the best bet is to test fit if possible or take carefull measurements.
JV69z/28rs is offline
post #3 of 3 (permalink) Old Sep 18th, 06, 06:03 AM Thread Starter
RJ
RJBaileyrn's Avatar
Re: 69 wheels
Thank you sir, The tires I have on now look like they would fit just fine if I had the corect backspace. I thank you much for your response. I will heed your recommendations. Sincerely,
RJ
69 coupe tires and wheels question RJBaileyrn Wheels & Tires 2 Sep 13th, 06 06:27 AM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 11:44 AM
DF Wheels 68camaroz28 Camaro Tech 2 Feb 14th, 06 05:52 AM
What type of wheels to get... Kens68 Wheels & Tires 6 Jan 2nd, 04 07:06 AM
'87 IROC wheels on '89 Firebird gjacobs Wheels & Tires 1 Jun 7th, 01 02:19 AM
