What tire size for a 69 Z28? - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 25th, 06, 04:04 PM Thread Starter
Anthony
Hello,
I am looking at getting some different size tires for the Z. Right now it has 215/60/15 BFG's. These tires are a full inch shorter than the originals. This of couse makes my gearing lower and changes my speedometer reading. My 3.73's feel like 4.10's or lower...
My question is:
What size tires are people typically running on these things without rubbing? I do want the same size tire at all 4 corners.
The wheels I have are rally wheels. I just want it to look and drive right. A few that I have seen were either running 245/60/15 or 235/60/15. To get to the stock height I would need to be at 26.6 in tall. A 245/60/15 BFG is right at 26.5. Will these rub? Or I guess I could run a 70 series tire...
Thanks,
Anthony
WAC
TX
69 Camaro SS/RS X22 L78, 4spd, Hugger Orange, Houndstooth Interior
70 Chevelle SS LS5 w/ 77k Original Miles, #'s Matching, Auto, Cowl Hood, Buckets, Tripple Black
W.A.C is offline
post #2 of 11 (permalink) Old Sep 25th, 06, 09:56 PM
Re: What tire size for a 69 Z28?
From what I understand the 245/60/15 will rub on the front of any first gen Camaro. (Someone else please confirm)
Playing with the numbers it looks like a 225/65/15, 215/70/15, or 235/60/15 are your best bet to get the height you desire.
215/70/15 - about 26.85 inches tall - mighty narrow
225/65/15 - about 26.52 inches tall - not a common size
235/60/15 - about 26.10 inches tall - wide and readily available
For reference, your 215/60/15s are about 25.16 inches tall.
Hope this helps.
Donald
68 Camaro convertible (resto on hold)
MytMini is offline
post #3 of 11 (permalink) Old Sep 26th, 06, 08:09 PM
A 245/60/15 rubs but just barely, depending on the vehicle tolerance, could get more to none. Its on the edge. My experience though is mostly '68
1968, M20 PDB 12posi-3.73 400SB (KB125 5.7"r AFR195 CS286H 750cfm-mech-annular_boost 10.2CR AirGap 6AL)
rogue68 is offline
post #4 of 11 (permalink) Old Sep 27th, 06, 05:34 AM Thread Starter
Anthony
Then I will probably stick with 235's...
Thanks for the help!
WAC
TX
W.A.C is offline
post #5 of 11 (permalink) Old Sep 27th, 06, 06:33 AM
I have 215/65/15 bfg's on my 69z28 with stock rebuilt suspension. They fit nice on 15x7 rallye wheels without rubbing, and fill the wheel well without looking to small.
Dave69Z is offline
post #6 of 11 (permalink) Old Sep 28th, 06, 11:47 AM
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
I used 235/60/15's BFG TA's, no problems, using stock wheels. (15 x 7) YH's. Looks nice and a wee bit aggressive without looking fat.
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #7 of 11 (permalink) Old Sep 28th, 06, 05:49 PM
ChuckD, can you post a picture? I'd like to see those 235s on all 4 corners. Thanks
Lemans Blue 69 RS/Z28
John3366 is offline
post #8 of 11 (permalink) Old Sep 28th, 06, 09:49 PM
"Tri-Tip"
Gary L's Avatar
215/65R15 on 15x7 and 24 tooth speedo gear is dead nuts on. 235/60R15's rubbed.
Gary L is offline
post #9 of 11 (permalink) Old Sep 29th, 06, 11:12 AM
The tire size calculators show the 235/60/15 and the 215/65/15 to be nearly the same in all dimensions except for the width. The 235 is about 3/4" wider. Is 3/4" the difference between rubbing or not?
John3366 is offline
post #10 of 11 (permalink) Old Oct 3rd, 06, 01:23 PM Thread Starter
Anthony
Anyone running these?
E70/15 – Speedway Wide Tread RWL Goodyear
WAC
TX
W.A.C is offline
post #11 of 11 (permalink) Old Oct 4th, 06, 04:08 AM
The P215/65/R15 was used on the 1982-1987 Z28 Camaro's with 15" wheels. It was the O.E. Size. Note I said Z28's, not IROC-Z's I know this because I had a 1984 Z28 with that size and I sold tires at one time back in the day. My 1988 IROC-Z had P 245/50/R16's on it.
The P 235/60/R15 is a little wider and a little shorter and will give you a wider footprint/contact patch on the ground than P215/65/R15 This will help cornering, braking and dry traction. The 235's are what I replaced my 215's with on my 1984 Z.
I ran P245/60/R14's on the front of my first and since sold 1969 Camaro without them rubbing, on a 14x6 Rally wheel. On the 2nd 1969 I bought a few months ago I now run a 15x7 Rally wheel with P 235/60/R15's all the way around. They haven't rubbed yet. I heard that these do rub on a car with weak coil springs and in some cases on the rear wheel housings with weak leaf springs. But most guys I know are very happy with P235/60R15's on a first gen Camaro with a 15x7 wheel. I'm curious to see if they will rub on 15x8 Rally's all the way around.
The Z28's in the late 1970's and the Corvette's as well used P225/70/R15's on them. These were also used on police cars (Impala's,Caprice's,Crown Vic's and some Mopar's) up until the early to mid 1990's when most cars started going to 16" and even 17" wheels and or the product was redesigned or dropped in favor of another model.
I hope this info helps!!
Good Luck!!
69 Camaro Z28 Original Detail Pics firstgenaddict Restoration Corner 253 Jul 30th, 15 08:28 AM
Swapping Guages on a 69 z28 jokernj1 Electrical & Wiring 1 May 19th, 06 05:57 PM
What tire size are you running thorpe67RS Wheels & Tires 21 May 5th, 06 09:48 AM
69 Z28 original leaf springs tyrfryrtom Brakes, Suspension & Steering 7 Mar 12th, 06 11:26 AM
Rear tire size limitations with stock fender well size??? BuddyP Wheels & Tires 4 Apr 1st, 05 02:03 PM
