front tire rub - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 12th, 06, 12:41 PM Thread Starter
front tire rub
I have P235/60 R15 Goodrich Radial T/As on my '68 in front. I get tire rub when hitting a dip or bump, especially if there are passengers in the car. Any simple suggestions to alter the suspension so it won't bottom out? I've heard there may be some spacers that would fix the problem. Thanks
68fan is offline
post #2 of 3 (permalink) Old Oct 14th, 06, 09:10 PM
Re: front tire rub
I have used spacers in the coil springs before, and it works okay, but screws up you suspension. What size rims are you running? From all that I am reading, a 15 x 7 with 4" or 4 1/2" backspacing should work. I am getting ready to change out my wheels, and was going to go to 235/60/15 with 15 x 7's up front.
frankc5601 is offline
post #3 of 3 (permalink) Old Oct 14th, 06, 10:42 PM
Re: front tire rub
It sounds like the front springs are tired. You can get a set of Moog front springs fairly reasonable. Go to the suspension forum and do a search - better yet go to David Pozzi the moderator's site and get more suspension info than you can even imagine. He has a list of springs and spring rates you can choose from. Good luck.
JV69z/28rs is offline
Tire rub on front (67) Advice needed. Brackneyc Wheels & Tires 10 Sep 5th, 06 09:27 AM
225/60 15 tire on 68...will they rub? newjob1975 Wheels & Tires 16 Jan 23rd, 06 07:22 AM
FRONT TIRE RECOMMENDATION? camaro man Wheels & Tires 4 May 29th, 03 03:05 AM
need front tire size with Gulstrand ochrisl Brakes, Suspension & Steering 9 May 28th, 03 11:04 AM
