1969 Camaro w/ Torq Thrust II's - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 13th, 06, 05:03 PM Thread Starter
Just bought a set of 15x7 Torq Thrust II's with tires, and now need a set of rears for my '69. Is the 15x8 with 4.5" backspace a correct choice, and can I put a 275/60/15 on them without clearance issues? Suspension is all stock, with multileaf springs.
Thanks in advance!
Macs69 is offline
post #2 of 8 (permalink) Old Oct 14th, 06, 01:37 PM
Re: 1969 Camaro w/ Torq Thrust II's
Check out this link. It says to use 15 x 8-1/2", 4-7/8" backspacing and that 28x10.5 rubber will fit.
I also have a '69 that will be getting new rims and rubber this winter.
http://camarotech.com/WheelsAndTires.html
69OlympicGoldSS is offline
post #3 of 8 (permalink) Old Oct 14th, 06, 01:43 PM
Bob
I have a 69 with exactly that, 15x8 with a 4.5 back spacing and 275x15 tires. Its a tight fit, but they fit fine.
They look good too
bob
Bgonz 69 is offline
post #4 of 8 (permalink) Old Oct 14th, 06, 08:14 PM
I would use a 9" rim with a 275 (5.5" bs) but an 8 w/4.5" will work.
post #5 of 8 (permalink) Old Oct 16th, 06, 04:44 AM
Jim,
I have seen you post a couple of times that you would use a 9" rim with a 275 (5.5" bs) but an 8 w/4.5" will work.
Have you actually done the 9" / 275 combination on a 1969 Camaro? I am ready to purchase a set of Torque Thrust II's and would rather have the 9" than the 8" (more "visual" depth).
Not questioning you, just want to make sure my hard earned cash doesn't turn into restocking fees.
Last edited by 69OlympicGoldSS; Oct 16th, 06 at 06:53 PM. Reason: I can't spell for [email protected]#
post #6 of 8 (permalink) Old Oct 29th, 06, 10:15 AM
To the original post, I have 15x8, 4.75 back spacing, 275/60/15 BFG Drag Radials. I have mono-leafs. Just by eye-balling it, the 4.5 back space will fit.
Updated picture:
Bill Miller is offline
post #7 of 8 (permalink) Old Oct 30th, 06, 02:42 PM
Rex
Nice view.........
Updated picture:
69 x-11..LS1, 420.88 horse to the tires,750 Holley Ultra DP, Torquer V2, darksides headers, PRC heads, 10.8:1 compression, forged bottom end, 5 speed. 2008 King Ranch F150 4x4.
trex70 is offline
post #8 of 8 (permalink) Old Nov 13th, 06, 06:28 PM
Bill
i have this combination on my '69 convertible ... torque thrusts w/4.5 backspacing and 275/60R15 tires. i did have a slight problem with the drivers side outside edge of the fender rubbing the tire. i increased the rear shackles by about a 1/2 or so and no more problems.
Bill
1969 Camaro RS Convertible, 350/700R4, front disc brakes,8.5 10 bolt rear w/ 3.73 posi
1999 Camaro Z28 m6 345K miles
billscamaros is offline
1969 camaro clutch pedal Spirit1 Troubleshooting 3 Apr 5th, 06 08:24 AM
DIY Network 1968 Camaro Restoration Show Brentmc Bench Racing 2 Mar 14th, 06 09:41 AM
69 Camaro Torq Thrust 2 lug nut, what type? Buildinga55 Wheels & Tires 4 Mar 1st, 06 06:43 PM
2005 SuperCar Reunion & Outdoor MuscleCar Show Sept. 2 & 3 CamarosRus Team Camaro Cruiz-Ins 19 Sep 7th, 05 06:53 PM
17 inch torq thrust 2's on a 68 camaro??? 1968camaro123 Wheels & Tires 7 May 19th, 01 08:23 PM
