15 x 10 Centerline, Will they fit ? - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 20th, 06, 05:24 PM Thread Starter
wayne
I have a set of 15 X 10 Centerlines with a 3 5/16 back spacing. Will these fit on my stock 69 camaro and what size of tire can I run on these? It doesn't matter if they stick out of the fenderwells but I'd like to keep them from rubbing.
69 IN PROGRESS,new trunk floor,new rear frame rails, inner outer wheelwells, floorpan ect.ect.ect. I have
to quit coming here.
together is offline
post #2 of 5 (permalink) Old Oct 20th, 06, 08:58 PM
Re: 15 x 10 Centerline, Will they fit ?
I run 17x 9.5 with a 5.75 backspace and they are inside the wheelwell . I don't like when they stick out .
Mark .
pictures can be viewed at
Mark .L.W. is offline
post #3 of 5 (permalink) Old Oct 22nd, 06, 07:26 PM
Steve69SS396's Avatar
I'm running the same wheels but with 4-3/4" back spacing with 28" X 10" slicks or 265/50/15 radials. You will have to raise the back of the car to get it to clear the tires, which is not desirable. You need more back spacing.
Steve69SS396 is offline
post #4 of 5 (permalink) Old Oct 23rd, 06, 11:42 AM
which is not desirable. LOL agree
glock73110 is offline
post #5 of 5 (permalink) Old Nov 15th, 06, 08:00 PM
Probationer
Derek
so a 15x10 with 4 3/5 back space will fit in the wheel well of a first gen?
my67rs396 is offline
heater core fit 69pace Heating & Cooling 8 Jan 11th, 09 07:55 PM
Big Block 'fit' questions?? bigblockgirl Engine 8 Nov 10th, 05 03:43 PM
94' Z28 what motors fit? '540 Chevelle Fourth Generation 10 Sep 26th, 05 09:19 AM
Rear axle centerline to the front spindle centerline distance bad68 Camaro Tech 4 Sep 25th, 05 07:50 PM
69 Camaro w/ac and ps headers fit problem? Yankit Engine 3 Jun 14th, 05 05:09 AM
