17" vs 18" question/debate... - Team Camaro Tech
post #1 of 15 (permalink) Old Oct 30th, 06, 05:30 PM Thread Starter
I'm sure it's been discussed before, but here goes anyway. My '69 currently has some low budget 18's now, and as part of my resto, I will be putting on some new Billet Specialties wheels. I like the look of bigger wheels, but I'm not sure if 18's actually do look better the the 17's I've seen posted on this forum.
Chris986S is offline
post #2 of 15 (permalink) Old Oct 30th, 06, 07:18 PM
Re: 17" vs 18" question/debate...
I went thru this same debate, but settled on the 17's. I went with 9.5" rears & 8" fronts. The 18's looked weird from certain angles to me. The just looked tall & skinny. I also thought the 17's would give a little better ride with the slightly taller tire sidewall. The only 18's that really looked better to me than 17's were ones that were 9" front & 10.5 or 11" rear. These obviously require more mods like mini tub & front suspension components. All the added cost drove me away from the 18's. Just my take, but whatver you like is what you should go with
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 15 (permalink) Old Oct 30th, 06, 07:33 PM
BonzoHansen's Avatar
I like 17s. Anything bigger doesn't have enough sidewall for me - visually or to handle our bumpy streets effectively. Just my $.02
TC Member #13
BonzoHansen is offline
post #4 of 15 (permalink) Old Oct 30th, 06, 09:57 PM
Definitely go 17", check out my sig for pictures of my 9.5 width rears and 8 width fronts, all 17", I feelthey visually look better than 18s, plus they cost less for the rims and tires!! I feel the proportions are just right for 17s on our camaros, of course my opinion....
and
Brian Lewis is offline
post #5 of 15 (permalink) Old Oct 30th, 06, 10:03 PM Thread Starter
Thanks for the responses...helped me to confirm 17's are the way to go. By the way, what size tires?
post #6 of 15 (permalink) Old Oct 31st, 06, 07:07 AM
Ted
Kumho ECSTA SPT (TireRack)
235/45WR17 - $79
275/40WR17 - $107
Rims: $985 shipped w/lugnuts/valve stems - Karen 1-800 - 731-4870
Front: 17x8 (4.75" bs) - 5x4.75 pattern (American Racing 505-7863)
Back: 17x9.5 (5.5bs) - 5x4.75 pattern (American Racing TT2 custom)
This info was provided to me when I saw Brians sweet 69 camaro by him.
I also have a 69 soon to recieve a new pair of boots. The shipping on the wheels may vary and the custom rears were $40 - $50 more per wheel. Just give the 800 number a call and ask for Karen for exact pricing to your location.
tgifford5 is offline
post #7 of 15 (permalink) Old Oct 31st, 06, 07:12 AM
Ted
I also forgot to add they are also on ebay under the seller of gonefishing69. The same 800 number as given before.
post #8 of 15 (permalink) Old Oct 31st, 06, 04:26 PM
Rod
If I ever upgrade next time I will buy 18s, I bought 17s. 18s fill out the wheelwell much better. With the right BS you can run 245/45/17s up front and 275/40/17s in the rear
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #9 of 15 (permalink) Old Nov 1st, 06, 04:51 PM
Backspacing above is correct for 69 only
$985 price was what I got from Karen at that 800 #, they have those sizes IN STOCK so I didn't have to wait for the custom 9.5" backspace rims!! $985 included the custom sizes + shipping + valve stems + lugnuts. Paid DiscountTire $65 total to mount/balance all 4 tires. Wold my old rims/tires using CraigsList for $400, making it about $1100 for the total upgrade from 15 to 17!
17" with those size tires fill out the wheel wells perfectly as shown in my signature on my site.
and
post #10 of 15 (permalink) Old Nov 1st, 06, 08:13 PM
How is the backspacing any different between a 69 and the other first genteration's? I will soon be buying 17's for the 67.
67 Camaro with 388 with Edleborck RPM heads, Air Gap, CC 282S, Tremec TKO
LukeSkywalker is offline
post #11 of 15 (permalink) Old Nov 2nd, 06, 06:18 AM
On a 67 you have a slightly narrower rear wheel well, so you are best off going with a 255/45R17 tire on the rear. Same backspacing is fine for a 9.5" wide rim.
and
post #12 of 15 (permalink) Old Nov 2nd, 06, 07:23 AM
Thanks, bummer on the narrow tire width.
post #13 of 15 (permalink) Old Nov 2nd, 06, 08:59 AM
Luke I do recommend you get 8" on the rear though for a 67, with that 255 tire size the 9.5" rim will stick out, looking funny! So go 17x8 (4.75" bs) - 5x4.75 pattern all around, cost will be probably about $50-$90 less because you won't need the custom 9.5" size
and
post #14 of 15 (permalink) Old Nov 2nd, 06, 06:16 PM
Sounds good thanks!
post #15 of 15 (permalink) Old Nov 4th, 06, 11:51 AM
6D9
Ron
I think the 18's looks much better than the 17's. 17's look like 15's to me now. The 18's put the top of the wheel much closer to the quarter lip and looks better. I plan to go with 18x10's with 275/40/18's with 5.75" bs. This will require cut or rolled lips and "massaged" in wheel wells. But the end result is worth it.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
Anyone running 17" on frt and 18" on rear? redvetteharley Wheels & Tires 3 Feb 21st, 06 08:54 AM
Alignment with 18" Wheels norcalcamaro Brakes, Suspension & Steering 3 Jan 26th, 06 01:46 PM
Widest 18" tire in the rear of a first gen.? q2quest Wheels & Tires 0 Jan 8th, 06 12:14 AM
I need some pictures of the 17" Wheel Vintiques Billets q2quest Wheels & Tires 7 Nov 24th, 05 10:48 AM
pics of 11" rotor on a 17" front dbackse350 Brakes, Suspension & Steering 3 Nov 11th, 05 04:14 PM
