Biggest Wheels & Tires for 69 RS CONV. - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 4th, 06, 03:55 PM Thread Starter
bbm
Apprentice
Dan
I recently bought a 69 RS Convert. Looking for tires and wheels. What's the widest wheel/tire in a 15" and or 17" that will fit without cutting the body. It has a 10 bolt single leaf now,I'm going to install a 12 bolt multi leaf later. (unless someone has a better idea) My friend had a 69 RS Coupe and he thinks his Billet Spec. wheels were 17x9 w/ 5" Backspacing and 245/40/17 or 245/45/17 tires all the way around. It looked good (lowered) but with the Z-rated tires darted around on the rutts in the road.I like the look of the 17's if I could get some in a lesser speed rating that would drive better I would but would rather go 15" and have it drive better on our crappy roads. The car has 15x8 repro. ralleys w/4" bs now and 245/60/15 and they just barely rub occasionally. Any ideas appreciated.
bbm is offline
post #2 of 2 (permalink) Old Nov 12th, 06, 03:54 AM
Re: Biggest Wheels & Tires for 69 RS CONV.
BBM,
On the front if you are looking to go w/ 15" I would go w/ P235/60/R15. I was going to go 15x8 w/ P235's or P 245's but a guy I know said he had 15x8's w/ 245's on his and the barely rubbed like yours does now. He suggested the 15x7's with 235/60's on them. That's what I went with and I decided to put them all the way around.
For what it's worth the conversion for a G60x15 is about a P235/60/R15. I believe F60x15 converts to P 225/60/R15. The 2nd gen's in the late 1970's came with P 225/70/R15 and the early 3rd gen Z's were P 215/65/R15.
As far as the 17" on the rear you should be ok with the sizes you mentioned. Although I have seen some guys try to stuff a Corvette sized P 275/40ZR17 under there. That means you gotta be perfect with backpacing & clearance. Stick with the rear sizes you mentioned.
Make sure you check ALL clearances along with measuring your backspacing.
Here are some helpful tire conversion charts.
http://www.barretire.com/Main/INCHUP.htm
http://www.mopar1.us/tireconversion.html
http://www.turbinecar.com/tires.htm (for you bias ply to radial conversion guys out there)
Good Luck with your 1969!!
Wheels & Tires on a 67 SS 67ssblue Wheels & Tires 4 Apr 6th, 06 11:57 AM
Need input on wheels and tires jtv68 Wheels & Tires 1 Apr 3rd, 06 06:19 PM
Forum Suggestion For Wheels & Tires Rack Man Camaros.net Site Help Discussion 6 Feb 8th, 06 10:22 AM
What size wheels and tires? HaulnSS Wheels & Tires 2 Feb 7th, 06 05:55 AM
tires/ wheels (my turn) the lip Wheels & Tires 2 Apr 27th, 05 06:36 AM
