Drag Race Wheels, Pictures, Opinions? - Team Camaro Tech
View Poll Results: Which Combo?
Cragar S/S, front/rear 2 25.00%
TT2, front/rear 1 12.50%
Bogart D10, front/rear 1 12.50%
M/T E.T. Drag, front/rear 0 0%
TTD, front/rear 0 0%
Alumastar 1-piece front, Alumastar Rear 2 25.00%
Alumastar 3-piece front, Alumastar Rear 0 0%
Wheel Vintiques Cruzer, front/rear 0 0%
American Racing Trakstar 1-piece front/Trakstar rear 1 12.50%
American Racing Trakstar 3-piece front/Trakstar Rear 1 12.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
post #1 of 7 (permalink) Old Nov 8th, 06, 08:44 AM Thread Starter
Matt
I'm looking for some opinions on new wheels for a '69. Regardless of style, the wheels will be either 15x8 or 15x10 with ~4.5"-4.75" of backspacing, running a 275/60R15 tire in the rear, and a 15x4 or 15x3.5 with a 165R15 Volkswagon tire in the front. The car is not lowered, in fact, I might use a hair longer shackle to raise it up if need be, but no more than an inch or so. I'll eventually move the shocks inboard for more clearance, and roll the fender lip. Also, I've heard of Stock-class racers having a small, triangle-shaped wedge cut out of the rear fenderwell, then welded back together so that it looks stock. I doubt I'd have to go this far with a 275/60R15 tire, but with a 30x9 or similar-sized slick, I might have to just as a precaution. I'm looking for anyone with any of the following wheel combo's for pictures, sizes, etc. Most importantly, these wheels will be used on the street, with cheap street tires, and I'll have a seperate set of wheels and tires for use with slicks. I know some of the higher end race wheels are not intended for street use, but I'm hearing that this results from manufacturers not wanting to spend the extra money to have these wheels DOT certified. Take, for instance, the Weld Alumastar 2.0 one-piece front wheel. If it can stand up to a landing from a 4ft. wheelstand, then shouldn't it be able to hold up on the street? Any pictures or opinions of these wheels on any first-gen would help (pictures of more common wheels, i.e. TT2, Cragar S/S are readily available):
Front:
Weld Alumastar 2.0 three-piece
Torq-Thrust II
Torq-Thrust D
Weld Rodlite
M/T E.T. Drag
Cragar S/S
Bogart D10
Back:
Weld Alumastar 2.0
Torq-Thrust II
Torq-Thrust D
Weld Rodlite
M/T E.T. Drag
Cragar S/S
Bogart D10
Matt
1969 Nova
1969 Camaro
1973 Camaro
Follow my '69 Build:
69Nova is offline
post #2 of 7 (permalink) Old Nov 8th, 06, 01:49 PM
Re: Drag Race Wheels, Pictures, Opinions?
A wheel stand and a off ramp will give very different loads.
I'm running Weld Prostars 15x5 w/ 3" bs front and 15x8 w/ 4.5" bs rear. The wheels are DOT approved. Now as for tires I have Dunlops 205/65/15 fronts and 285/60/15 SH McCrearys rear (both with DOT stamps) The rear tires are very tight and do rub on hard turns and off camber bumps like turning into a driveway.
I know the Draglites and Prostars are very popular but I do like the Rodlites too
I hope this helped some.
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Nov 8th, 06, 05:32 PM
You've got mail.
69 RS 408 sb Canfields, Comp. solid cam, TKO, 373's
Best ET: 10.87 122.49 mph with auto. trans.
NC69RS is offline
post #4 of 7 (permalink) Old Nov 8th, 06, 08:04 PM
Harley D
HarleyD67's Avatar
Aluma Stars
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]115.59
HarleyD67 is offline
post #5 of 7 (permalink) Old Nov 8th, 06, 08:05 PM
Harley D
HarleyD67's Avatar
Draglites
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #6 of 7 (permalink) Old Nov 8th, 06, 08:05 PM
Harley D
HarleyD67's Avatar
Convo Pro's
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
post #7 of 7 (permalink) Old Nov 8th, 06, 08:07 PM
Harley D
HarleyD67's Avatar
All of the wheels I posted are DOT in most sizes. (not all) I tried to keep the pics to 800x600 for dial up I will re-size if it's an issue.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
69 Camaros on television and movies jsg1010z Bench Racing 35 Aug 15th, 10 05:28 PM
Wings and Wheels Car Show, Middle Georgia, Oct. 15th Dwight's Z/28 Team Camaro Cruiz-Ins 0 Oct 4th, 05 09:43 AM
Wheels Won't Fit New Disc Conversion... Jeff Stover Brakes, Suspension & Steering 5 Jul 8th, 05 05:50 AM
Drag wheels and tires SnakeEyes Wheels & Tires 9 Jun 4th, 05 05:50 AM
Can I get my Aluminum Wheels Chrome Plated? Joel Koontz Wheels & Tires 3 Feb 28th, 01 07:24 AM
