15" 3rd gen z28 wheels on 2nd gen - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 11th, 06, 06:13 AM Thread Starter
Andrzej aka Andy
Hi there i currently have chrome steel wheels on my 2nd gen camaro, which are begning to show their age! IE rusting
The tyres are 235-60-15 from memory might be 65 profile but no larger.
They are a bit tight on full lock and unable to go over bumps etc with passengers in the rear without scraping the side wall.
I have recently purchased a nice set of early 3rd gen z28 the 5 spoke gold face type, i have tet fitted them as of yet do not have tyres and wondering what size of tyre I will need to install?
I have looked at the links for correct tyre size etc but the chrome wheels have a lesser offset thus sticking out further in the wheel arch. Where as the z28 rims are some what recessed in the wheel arch!
so do I need wheel spaces to bring out the wheel for a similar tyre size?
Or would 225-55-15 be a better choice?
Cheers
Andy
My camaro will live again!
andrzejbubez is offline
post #2 of 8 (permalink) Old Nov 11th, 06, 06:35 AM
Mitch
Lost in the 60's's Avatar
Re: 15" 3rd gen z28 wheels on 2nd gen
The 235-65-15 tire is the stock size and should fit very well on the correct offset Z28 wheel. The reason you have fitment issues with them now is because of the "reverse dish" offset of the chrome weels. If it isn't too costly, have one of your current tires mounted on a Z wheel and test fit. You should be able to go with an even larger footprint than a 235, with the correct offset wheel.
Lost in the 60's is offline
post #3 of 8 (permalink) Old Nov 11th, 06, 06:36 AM
Welcome to the Club! Portsmouth? England. Nice country southern England.
3rd Gen wheels have different offset (backspacing) so measure the wheel and put the least offset onto the front. This way they won't rub the control arms. I believe also, you'll have to get lug nuts with the 3rd Gen taper and SAE threads.
You may have to get spacers to space the wheels out to prevent rubbing. Longer studs will be needed. Dorman sells a longer stud. You might check www.rockauto.com and see what they have to offer, in both stud and nut.
Good to read from another across the water.
post #4 of 8 (permalink) Old Nov 11th, 06, 07:02 AM
Mitch
The 15" wheels are all the same offset...it is the 16" wheels that are different.
post #5 of 8 (permalink) Old Nov 11th, 06, 06:41 PM
andrzejbubez,
I had a 1984 Z28. The original equipment tire size from the factory on the standard 5 spoke aluminum wheels for 1982-1987 Z28's was P 215/65/R15. This was also used on standard RS Camaro's in 1989 through 1992.
Many people including myself replaced the P 215/65/R15 on a 3rd gen with P 235/60/R15. The 2nd gen Z28's which came equipped with radials in the late 1970's were P225/70/R15. P 215/65/R15 was also used on FWD Cutlass & Grand Prix's from 1988 -about 1992.
GM used P 225/70R15 on the Corvette's, Trans Am's, Z28's and police cars in the late 1970's. The police used that size until 16's came on the scene in the mid to late 1990's.
I have owned 4 Camaro's. Two first gen and two 3rd gen. My other 3rd gen was a 1988 5.7L IROC-Z and those were P245/50/R16's.
Last but not least all four of these cars were bone stock & original when I got them. I also was in the tire & auto game for the entire decade of the 1990's until about 1998. Little did I know then what I know now.
Bottom Line: Measure the back spacing, check clearances. I've seen lots of guys used 3rd gen wheels on 2nd gen cars. This happened mostly betwen 1978-1981. I know the calipers are different in 1979-1981. P 215/65/R15, P 225/70/R15 & even P 235/60/R15 should clear the fenders on a 2nd gen with ease.
post #6 of 8 (permalink) Old Nov 12th, 06, 01:11 PM Thread Starter
Andrzej aka Andy
I know there is no problem with brake calipers as I have test fitted one wheel upfront as I am currently upgrading to a chevy 350 small block from buick v6 which was originally on the car.
With the current offset on the chrome steel wheels there are ocasions where the 235-65-15s rub on full lock on one side of the innter wheel well.
this is why I believe that placing the existing tyres on the Z28 rims will foul even more and hence the question.
Cheers for the imput as greatfully recieved and good to know that this site is a haven for assistance
Andy
post #7 of 8 (permalink) Old Nov 12th, 06, 02:34 PM
BonzoHansen's Avatar
Should be no issue to use them on a 2nd gen.
www.nastyz28.com
TC Member #13
BonzoHansen is offline
post #8 of 8 (permalink) Old Nov 12th, 06, 11:12 PM Thread Starter
Andrzej aka Andy
I know there is no issue with the actual fitment its just down to tyre choice on the rim.
Going back to the 215-70-15 would this not cause a similar problem with the lack of space in the front wheel wells? ie on full lock with no wheel spacers would rub on the arches?
As per another site the information given for 15" rims is 225-55-15 for the front
http://www.chevyhiperformance.com/te...es/index2.html
why is it so expensive to restore?? RUSTY69 Bench Racing 54 May 1st, 07 11:04 AM
70 Z28 / 71 SS and up wheels m22mike Wheels & Tires 2 May 1st, 06 07:34 AM
Thought someone might find it usefel, others dishearting!! Parts list of my project! boilermaker Camaro Tech 20 Apr 7th, 06 09:14 AM
15" or 16" wheels for dog dish hubcaps blackss69 Wheels & Tires 0 Feb 27th, 06 07:11 AM
