Spring or Shock swap - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 11th, 06, 07:19 AM Thread Starter
Well, fina'lly a picture of the 68'. What I would like to do is get a little more lift out of the rear and drop the front slightly. I want to go to 285/60R15 BFG's on the back mounted on a 15x8 Rally Sport wheels. I believe a 4.5 BS should suffice. I don't want to use air shocks, but at the same time I understand that new monosprings on the rear will eventually sag. Year One sells a mono leaf that can be order with as much additional lift as you need. Does anyone have any experience with this swap?
Roadman is offline
post #2 of 10 (permalink) Old Nov 11th, 06, 09:32 AM
TDW
Tony
Re: Spring or Shock swap
I don't know about the mono leaf, but I had Eaton make a set of multi leafs for my Nova that are 1 1/2" taller than stock. They work great.
TDW is offline
post #3 of 10 (permalink) Old Nov 11th, 06, 01:50 PM
Lucky68's Avatar
I personally like the current stance of you car. I think 285 are going to give you some rubbing problems even back spaced correctly. I've got 255/60R15 on my with 4.5 backspacing which fit perfect. No rubbing but very close. Do some more research because there's an infinite amount of info on the subject. I went with the 255's because I didn't want to deal with any rubbing issues.
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
Lucky68 is offline
post #4 of 10 (permalink) Old Nov 11th, 06, 04:15 PM
Put some Eibach Front Springs PRO-KIT 1" Drop - Part Number 3848.120 on the front, leave the rear alone, maximum you can clear on a 68 is going to be 255s, 275s if it was a 69.
and
Brian Lewis is offline
post #5 of 10 (permalink) Old Nov 11th, 06, 06:21 PM Thread Starter
Thanks to everyone who responded. I will probably go with the 255's with the 8" Rally Sport wheels. I personally don't care for Torque Thrust II's that are on the car or the white letter tires. It didn't come with white letter tires from the factory and to me it looks out of place. This car came out of Calhoun County Georgia and found it's way to Michigan.
Larry
Roadman is offline
post #6 of 10 (permalink) Old Nov 12th, 06, 03:01 AM
TDW
Tony
Larry...Where are you at in Mich? I am just outside of Flint.
TDW is offline
post #7 of 10 (permalink) Old Nov 16th, 06, 09:14 AM
Robert
The stance of your car looks perfect, jmho, i wouldn't change a thing
We do not possess imagination enough to sense what we are missing.
robert68 is offline
post #8 of 10 (permalink) Old Nov 16th, 06, 06:25 PM Thread Starter
Robert68,
Thank you for the nice compliment. I am going to go with the 255/60R15s on the back instead of something bigger. I am also going with chrome 8" Rally Sport wheels on the rear and 15x7" on the front with the current 215/60R15's that are pictured. The car sets level but I would like to have it slightly raked. I would like to try the Hotchkis 2" lower springs in the front to achieve this look. Nothing will happen until Spring, but a least I will have the parts ready to go.
Larry Boyd
Roadman is offline
post #9 of 10 (permalink) Old Nov 17th, 06, 05:55 AM
Ted
The 3 leaf mono replacement springs from JCW helped raise my saggy rear on my 69 monoleaf. I just got my Eibach 1" lowering front springs yesterday from Jeg's. I will also be replacing the front bushings/ball joints/tie rod ends/shocks and sway bar. Nice GO-MARO!
tgifford5 is offline
post #10 of 10 (permalink) Old Nov 18th, 06, 01:30 PM
Jason
jay'srs/ss's Avatar
Sweet looking ride!
My Cars:
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
SOLD!!!
88 Camaro IROC-Z SOLD!!!
SOLD!!!
jay'srs/ss is offline
Front coil spring rubbing frame,Help! NC69RS Brakes, Suspension & Steering 1 Aug 24th, 06 01:04 AM
th400 Boost Valve Spring??? camaroman7d Transmission & Driveline 8 Jan 5th, 04 05:09 AM
69 front coil spring install ken69 Brakes, Suspension & Steering 6 Nov 1st, 02 06:42 AM
Front coil spring swap w/ from 78Z to 68 S_Snitily Tech 2000 1 May 5th, 01 09:08 AM
MONO TO MULTI LEAF SPRING SWAP BARRY Tech 2000 5 Jul 1st, 00 05:51 PM
