Biggest rears on 67? - Team Camaro Tech
post #1 of 11 (permalink) Old Nov 16th, 06, 02:39 AM Thread Starter
OK. For probably the 1,000th time, looking for the biggest wheel and tire size to fit UNDER the rear wheelwells w/o rubbing. Would like tire to be around 28 in tall. Thinking like a 15 x 8 w/ a 255/65-15. All this w/ a 5.25 rear spacing. Opinions?
1967 Camaro SS 396
60'- 1.687
1/8 mile- 7.415 @ 93.49 MPH
1/4 mile- 11.608 @ 124.88 MPH
TazJr800 is offline
post #2 of 11 (permalink) Old Nov 16th, 06, 09:16 AM
Re: Biggest rears on 67?
i have 17 x8 with 4 1/2 bs w 255 45s w plenty of room to go in my 67 vert , hope this helps,chris
1967rsssconv is offline
post #3 of 11 (permalink) Old Nov 16th, 06, 09:46 AM
Strick
Plenty of room (?) inside - axle side, or outside quarter panel, or both?
Thanks!
Strick
Strick is offline
post #4 of 11 (permalink) Old Nov 16th, 06, 09:52 AM
I had 275/60 R15's with stock wheels and stock leafs...no rubbing at all. In fact, I still have them in garage if you live close to philly.
When I lowered, I switch to 17 wheels like chris.
67SSragtop is offline
post #5 of 11 (permalink) Old Nov 16th, 06, 02:47 PM
Tony
I run 255/60/15's on 15X8 Ralley's. I also have a pair of 275/60/15 DOT's on 15X8 Ralley's. No rubbing at all and the rear of my car is lowered.
Tony:
67 RS Clone, 388 SBC/Keisler TKO 600/12 bolt, 3.90 gear w/posi and a 250 shot of N2O for fun. See my progress at: password is camaro
idoxlr8 is offline
post #6 of 11 (permalink) Old Nov 16th, 06, 04:17 PM
275/60/15 (28"t x 10.5"w approx.) is it on a 15 x 8 wheel with 4.5" backspace.
68 Camaro~LSx ~all motor
post #7 of 11 (permalink) Old Nov 16th, 06, 04:39 PM
Harley D
HarleyD67's Avatar
As mentioned 275/60R15's fit well.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #8 of 11 (permalink) Old Nov 16th, 06, 05:28 PM
Smile Re: Biggest rears on 67?
The deal here is that you can probably run a 305/45-17 b/c the lower shock mount will tuck up inside the wheel!!
My old L-60/14's measure a modern 298/53-14 on 9" wide rims and need 3.5 b/s to clear the shock mount down low! By going to a 17" rim, I can gain about 1.5" offset inwards to help everything clear the outer wheel well lip..
I just ran coil-overs and raised my car up like 4" or so and they were fine to me!! Old-school all the way b/c they were right at the chrome lip on the outside!!
pdq67
PS., stock steel rim on my car is 14" x 6" w/ 3.75" b/s.
And fwiw, a 9.50-14, Firestone Town&Country M&S tire on my stock rims fit fine with my car raised up too!! They are like 29" to 29.5" tall!! My speedometer went from 70 to 82 mph at 3050 to 3070 rpm!!
post #9 of 11 (permalink) Old Nov 16th, 06, 05:51 PM
Jerry R.
jr68's Avatar
Like PDQ I also ran L-60-14's on my old school Camaro and they fit the same as these 275-60-15's and I could get away with my car a little lower than this.
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #10 of 11 (permalink) Old Nov 16th, 06, 08:14 PM
You talk about an "old-school" muscle-car look!! Big-n-littles!! E-60's and L's!!!
pdq67
post #11 of 11 (permalink) Old Nov 16th, 06, 08:37 PM
Jerry R.
jr68's Avatar
I used 225-60-14's on the front . Winding the clock back to my high school days. Back to when I used to get in to way , way , way too much cop trouble. But its ok I'm reformed now.
jr68 is offline
67 rear frame rail separation distance rjg67rs Body Shop 3 Sep 1st, 06 12:04 PM
QL code 67 Camaro 12 Bolt Rarerat Transmission & Driveline 2 Jul 5th, 06 09:55 PM
67 console refurb w/ gauge addition - pics - long 67FamilyFun Interiors 6 Jun 14th, 06 07:08 AM
Opions on value of 67 396 SS ? 67 owners please read ! 69 350 SS Bench Racing 18 Apr 21st, 06 07:57 PM
Pictures of correct OEM Gills, lights, 67, 68 Camaros ToyzShopGary Body Shop 5 Jan 15th, 06 07:26 AM
