68 camaro factory disc brakes - Team Camaro Tech
post #1 of 6 (permalink) Old Nov 21st, 06, 09:43 PM Thread Starter
Do I need a spacer on the front to clear the big caliper. Or is there a special offset I need. Thanks for your time.
orange camaro is offline
post #2 of 6 (permalink) Old Nov 22nd, 06, 04:09 AM
Re: 68 camaro factory disc brakes
IIRC, the '67/'68 used the 4-piston, JL-8 type jobbers that have a different caliper mount than the '69 and later, big single piston calipers. The '69 is bent similar to an "S".. whereas, I think the earlier one is straight or flat..
I forget if the 4-piston spindles will mount the '69 and newer bracket stock or not??
David, jump right in here....
pdq67
post #3 of 6 (permalink) Old Nov 23rd, 06, 01:55 AM Thread Starter
What I have Is a 68 with dual piston calipers, I want to know is. Is there a special offset I need on the front? wheels
post #4 of 6 (permalink) Old Nov 23rd, 06, 02:59 AM
Kevin
SixtyAte's Avatar
Paul,
I think he is asking about the rims because disk brake setups require rims that are for cars with disk brakes. I believe he needs some 4.5 backspace rallye wheels or stock gm rims from a disk brake car, again with the correct backspacing.
Kev
SixtyAte is offline
post #5 of 6 (permalink) Old Nov 23rd, 06, 07:12 AM
Please go over to CRG and look through their wheel section..
http://www.camaros.org/
B/c I flat don't know b/c my car came with 4-wheel drum brakes..
pdq67
post #6 of 6 (permalink) Old Nov 23rd, 06, 07:25 AM
Tony
XG rallys are correct for 68 with disc brakes. DG for 67's with disc, or you can use any other disc rally wheel.
tonycamaro is offline
69 Camaro Front Disc Brakes nooney Brakes, Suspension & Steering 5 Dec 30th, 05 09:07 PM
98-02 LS1 Disc Brake Conversion on '68 Camaro ItDoRun Brakes, Suspension & Steering 0 Oct 4th, 05 12:42 PM
interchangable disc brakes for 67 camaro 67 Livnhrd Brakes, Suspension & Steering 2 Oct 29th, 04 08:11 AM
69 Camaro SS Disc Brakes? chasd1 Tech 2000 4 May 5th, 00 09:04 AM
