69 Stock Camaro Rim options - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 27th, 06, 06:58 PM Thread Starter
Apprentice
Craig
I've seen several similar questions on this, but I want to make sure I get it right. My question is can I fit 17" tires (8" wide) on my 69 Camaro front and back. I have not modified the suspension at all. It has a 10 bolt rear. The tires I want to buy are P255/60R17. Will this work or will it be too tight? I also believe my wheel bolt pattern to be 5 on 5 (I measured to confirm 5" from edge of bolt to center of bolt across from it even though I've seen threads indicating it to be 4.75" for base 69 Camaros). Any feedback would be grdeatly appreciated. Thanks!!
CraigT69RS is offline
post #2 of 2 (permalink) Old Nov 27th, 06, 07:46 PM
Corey
Re: 69 Stock Camaro Rim options
Early chevys are 5 x 4 3/4. As for the rest, I can't help you.
apbtrock is offline
My 2 cents on the new Camaro...gotta say it clill Fifth Generation 77 Oct 24th, 06 06:28 PM
69 camaro will 15x10 with 5 1/2" BS fit stock body? NJTURBO Wheels & Tires 5 May 9th, 06 05:02 PM
69 Camaro Brake Booster Swap ? billscamaros Brakes, Suspension & Steering 2 Mar 24th, 06 05:28 AM
My first post and my first 69 Camaro (dialup beware pics) Lance-w Bench Racing 17 Jan 9th, 06 08:17 PM
