15" wheel on a C5 - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 30th, 06, 12:25 PM Thread Starter
madmax87's Avatar
15" wheel on a C5
I'm picking up a 69 subframe from a TC member that has a C5 brake setup on it. If I take the calipers off, can i put a 15" rally on it to just move it around?
madmax87 is offline
post #2 of 3 (permalink) Old Nov 30th, 06, 01:58 PM
Matt Jones
Re: 15" wheel on a C5
If it uses a stock Camaro spindle, then you probably can, assuming the brakes at 13" or so. Just measure the inside of your rally wheel..if it's less than 13", then it wont work.
If it's using a C5 knuckle, then it won't work at all. It's too tall.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #3 of 3 (permalink) Old Dec 1st, 06, 12:23 AM
if you have the caliper off the rotor should fall right off with it and then your rallys should fit, unless like Matt said it has a C5 spindle in which case i dont know...
400bird is offline
Can I use the 14" Rally Wheel Caps on 15" Wheels? POCKER Wheels & Tires 2 Jul 30th, 06 11:22 AM
widest 15" wheel & tire combo i can fit on my stock 68? bills68camaro Wheels & Tires 9 Jan 23rd, 05 04:59 PM
Anything I need to know on 15" wheel convert? click Wheels & Tires 6 Apr 6th, 03 05:27 AM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
