Wheel/tire combo question - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 19th, 06, 04:14 PM Thread Starter
Tony
I'd like to keep my gear ratio and speedometer reading stock so here's the question:
If I order a 17 by 8 wheel all the way around, what height tire would I need to not change the above? I'm thinking 60 series but not sure if that matters.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 2 (permalink) Old Dec 22nd, 06, 11:50 AM
Re: Wheel/tire combo question
you cant run a 60 size tire it will be to tall , and hit the wheel wells all the way around, that is on a 17 in rim max would be a 50 but even that is cutting it close
1967rsssconv is offline
GM practice of stamping engines question diggerdave Tag Team 2 Nov 2nd, 05 04:14 PM
Question about tach dash. wettpaint Camaro Tech 1 Oct 7th, 05 09:03 PM
68 camaro wheel/tire combo keith1365 Wheels & Tires 10 Aug 25th, 05 12:19 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
Another Proportioning valve question 1968_camaroSS Brakes, Suspension & Steering 6 May 2nd, 05 12:07 PM
