wheel changeover from 15x14 to ? - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 31st, 06, 08:39 AM Thread Starter
I have my deceased fathers 69 pro-street, 671 blown camaro and i am looking to update the 15x14 welds to a more modern look when i change over to air-ride shockwaves. The car is tubbed and the rear-end is narrowed.
My ? is-cna i run a 17x12 or something like that without changing the rear-end? If so, does anyone know who makes this wheel?
My idea was a classic muscle car like wheel-torque thrust?- but updating to 17x12 and 17x7. My only hang up with torque thrust is everyone has them.
dads camaro is offline
post #2 of 8 (permalink) Old Dec 31st, 06, 09:12 AM
Re: wheel changeover from 15x14 to ?
I don't know how tall your current combo is but Mickey Thompson has come out with a complete line of pro street replacement wheels and tires in the more modern large diameters but they maybe only 18s and 20s. Check it out. The bigest thing your going to have to overcome is overall diameter. Most of the tires that are 335s or wider are only 30 or even 25 series (335/30-18 or 345/25-20). Here's the link http://www.mickeythompsontires.com/s...em=SportsmanSR
Jack
JV69z/28rs is offline
post #3 of 8 (permalink) Old Dec 31st, 06, 10:43 AM Thread Starter
i am going to be running air-ride, so i should be able to compensate for the diameter, correct?
post #4 of 8 (permalink) Old Dec 31st, 06, 04:45 PM
In ride yes I would think so but what ratio rear is in the car? If it has 4:10s or 4:56s and there is a 31 or 32 tire on there and you drop down to a 26 tall tire the car is not really going to be very streetable (asuming that it is now with the blower motor in it).
Jack
post #5 of 8 (permalink) Old Dec 31st, 06, 06:04 PM Thread Starter
oh.. now i feel stupid..this is why i wish my dad was still around. i am running 4.11 gears in the car. wouldn;t the 17" wheel and lower profile tire be the same total diameter as the current combo with the mickey sportsmans-18x31.5? and the 15x14 welds?
this is why i love this site..i learn things that i would never have known.
i want my performance to be optimum and have a great looking muscle car.
post #6 of 8 (permalink) Old Dec 31st, 06, 08:31 PM
The tire on there now is 31.5" tall a 335/35-17 is 26.2" tall - that's a 20% difference. See what I mean?
Jack
post #7 of 8 (permalink) Old Jan 1st, 07, 11:22 AM Thread Starter
man..i was not taking that into consideration...i guess my only option is to stick with the welds???
post #8 of 8 (permalink) Old Jan 30th, 07, 12:08 PM
Really, it all depends on your current setup, especially the width of the rear end and the backspacing on your current wheels.
And as mentioned, your current rear end gear ratio vs tire diameter.
If you get a wheel that doesn't end up in the same location (side to side), your tire may be too far inboard or too far outboard and look stupid.
I'd suggest you first get your backspace measurement, wheel width, and overall tire diameter, and rear axle width (flange to flange).
Then you can start talking about specifics. And you may wish to call a wheel company tech and get a general idea of what wheel specs you should be looking at to get something that will work without changing rear gears or rear end housings.
BTW: I'm going through a similar exercise, as I want to change from the Weld Prostars to something that is different and requires less maintenance.
Good old fashioned Chevy Rally's are on the top of my list right now. Simple, clean, a classic look, etc.
Good luck.
Team Chevelle Gold Member, #178: '69 Malibu Pro-Street
'69 Camaro
'65 GTO, 4sp, 400ci, console, bucket seats
mjpell is offline
USING A DEGREE WHEEL TO DETERMINE CAM mark67ss Performance 10 Jul 26th, 17 05:33 PM
Steering wheel installation woes...HELP 68SSCamaroinKS Interiors 31 Jul 28th, 04 06:10 AM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
Crooked Steering Wheel Blk69 Tech 2001 6 Dec 16th, 01 09:02 AM
