New Rally Wheels - Which to buy for these tires... - Team Camaro Tech
post #1 of 10 (permalink) Old Dec 31st, 06, 02:07 PM Thread Starter
I'm going to purchase a set of Rally Wheels for the '69 from Ground Up. I need to know which set will fit my existing tires.
Tire size: P235/60R15
Which will fit this tire?
http://www.ss396.com/mm5/merchant.mv...SCOMPLETEWHEEL
or this
Or, if I decide to go with the Torque Thrust wheel, which size should I purchase?
Green RS is offline
post #2 of 10 (permalink) Old Dec 31st, 06, 02:25 PM
Dan
Re: New Rally Wheels - Which to buy for these tires...
I just bought a set of rally wheels this past summer.I bought the
15x7 with 4.50 back spacing.I put P 235x15x60 on the front and I put
P275x15x60 on the rear(see my signiture picture profile) This combo fits
perfect!!! No rubbing at all.
THIS IS MY STORY AND I'M STICKING TO IT....
__________________________________________________ ________
Hope this helps
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
post #3 of 10 (permalink) Old Dec 31st, 06, 02:37 PM Thread Starter
Thanks Dan. Are the rear wheels wider than the front? I suspect so, no? (or are they taller?)
Also, would the tires I listed above fit the first link (the 4.25 backspacing)?
Green RS is offline
post #4 of 10 (permalink) Old Dec 31st, 06, 02:43 PM
Dan
my ralley wheels are 15x7 with 4.5 backspacing all the way around.
My opinion is @ stock ride height you need the 4.5 backspacing with this wide of a tire in the front.
The tire is very close to rubbing with 4.5 bs
235/60-15 tires are 26"dia.and the 275/60-15 are 28"dia.and about
1"wider. But it fits great,with no [email protected] stock height.
I got my rally's at NPD
Hope this helps
_____________________________________________-
Dan
post #5 of 10 (permalink) Old Dec 31st, 06, 06:58 PM
madmax87's Avatar
I would think with the tire size your going with 235/60/15 that it would look better on the 15x7 rim. Putting it on a 15x8 might not give you the right side profile. I'm running a 255 on a 15x8 and looks pretty good. Just my opinion
madmax87 is offline
post #6 of 10 (permalink) Old Jan 2nd, 07, 09:57 AM Thread Starter
Quick question...
15x7 = 15 inch tall rim by 7 inches wide? Is that how that works?
Green RS is offline
post #7 of 10 (permalink) Old Jan 2nd, 07, 10:02 AM
Fred
77thor's Avatar
Originally Posted by Green RS View Post
Quick question...
YES.
77thor is offline
post #8 of 10 (permalink) Old Jan 2nd, 07, 10:25 AM Thread Starter
Perfect, thanks...
I have 15x8 rally's on the car now (with P235/60R15 tires). If I go to a 15x7, does this mean less rubbing than what I get now (which is little to none) and would it change the hieght of the car?
Sorry, just learning about tires and rims while thinking of buying some new wheels :-)
Green RS is offline
post #9 of 10 (permalink) Old Jan 2nd, 07, 12:15 PM
Dan
I have 2 sets of rallys, 1 sets of tires has 15x8 rims and the other has 15x7 rims and they both have p235/60R-15 tires on them.The set with the 15x7" rims the tire is 1/2"smaller (narrower) than the 15x8"rim. So that means you will get 1/4" more clearence with the 1 inch difference in rim wight.
Now remember that is with not changing the back spacing!!!
Now as far as changing the body height,this will not change.I went and I check this out for you, the two set of tires are the same in height
Hope this helps
Dan
post #10 of 10 (permalink) Old Jan 11th, 07, 10:04 AM
Marty
I believe the 4.25" backspacing is the most common. I just installed a set of 15 x 7 with 4.25" backspacing from Wheel Vintiques. I used P235/60 15 Indy Firehawks and have no clearance problems. You are lucky you have the tires. P235/60 15 is a hard size to find right now - no TAs to be found.
68RSconvTN is offline
GM Rally Wheels "XC" code-what Car? faninc Wheels & Tires 9 Oct 13th, 05 09:22 AM
need wheels and tires info help....... 68Dreams Wheels & Tires 0 Oct 11th, 05 03:24 PM
Tires Get An Expiration Date? BonzoHansen Bench Racing 46 Jun 7th, 05 08:17 PM
My new Wheels & Tires are on! Mike68RS Wheels & Tires 2 Jun 13th, 04 04:56 AM
Balancing Rally Wheels BH69Camaro Wheels & Tires 4 May 14th, 04 07:47 AM
