Offset question!!!!!!!!!!! - Team Camaro Tech
post #1 of 13 (permalink) Old Jan 30th, 07, 07:16 PM Thread Starter
What would happen if I got a smaller offset on my camaro like a 12 or 20?
subby is offline
post #2 of 13 (permalink) Old Jan 30th, 07, 08:42 PM
Re: Offset question!!!!!!!!!!!
what?
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is offline
post #3 of 13 (permalink) Old Jan 31st, 07, 07:49 PM
Paul
Is this a trick question?
1962vette is offline
post #4 of 13 (permalink) Old Jan 31st, 07, 08:28 PM
you'd have wheels that stick out slightly farther..
or maybe they'd be in slightly farther..
i'm a dumb lazy American, so i only understand backspacing..
you don't plan sincerity.
novaderrik is offline
post #5 of 13 (permalink) Old Feb 1st, 07, 09:42 AM
Need more infomation to properly answer your question. Type of chassis, wheel size and tire size would be a good start.
baz67 is offline
post #6 of 13 (permalink) Old Feb 1st, 07, 03:43 PM
Smile Re: Offset question!!!!!!!!!!!
It's just easier for us dumbies to think in terms of back spacing is all.
We take a rim width and subtrack b/s and we have front spacing OR the part that stick's out.. This part hits the wheel well lips!!
B/s sticks in towards the center of the car................... This part hits either the subframe or rear wheel well inner wall..
pdq67
post #7 of 13 (permalink) Old Feb 1st, 07, 07:14 PM
67 Camaros Rock
Joe Harrison's Avatar
Talking Re: Offset question!!!!!!!!!!!
It won't pass smog?
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #8 of 13 (permalink) Old Feb 2nd, 07, 10:50 AM
if you're gonna troll, please ask a better question than this..
really, this one makes no sense..
post #9 of 13 (permalink) Old Feb 2nd, 07, 02:56 PM
Darn GUYS!!
He's just talking in Millimeters is all!!
A lot of rims are sized in metric dimensions nowadays!!
I don't like it b/c I'm old-school, so have to convert over in my head to inches!!! Make's me think tooooo HARD!!
He, He!!
pdq67
post #10 of 13 (permalink) Old Feb 2nd, 07, 04:32 PM
pdq-
read the original question..
it's hard to say just WHAT he is asking..
but i've always wondered why rims are made in inches- except for those Mustang rims in the 80's- but tires are made in millimiters.
and why do late model and import guys use the offset spec- which changes when you go wider or narrower and is stated in millimeters- to fit rims that are designed using inches..
post #11 of 13 (permalink) Old Feb 2nd, 07, 05:45 PM
DjD
DjD's Avatar
What year are you talking about? Is that positive or negative offset? What is your current offset? This should help everyone understand offset vs backspacing...
https://www.rsracing.com/tech-wheel.html
...Dennis
DjD is offline
post #12 of 13 (permalink) Old Feb 2nd, 07, 07:07 PM
I have no problem converting mm to inches but I have to know where we're starting before I can figure out where we're going. subby feel free to chime in here any time now.............
Jack
JV69z/28rs is offline
post #13 of 13 (permalink) Old Feb 2nd, 07, 07:22 PM
Thanks Dennis for jumping in here..
pdq67
Offset ground crank question. rojo Engine 7 Aug 12th, 06 05:49 PM
Bumblebee stripe question (67) Brackneyc Body Shop 5 May 18th, 06 11:49 PM
big block transmission/shifter question jamesriediger Transmission & Driveline 11 Jul 6th, 05 02:08 PM
69 fuel line question - vapor return or not? Eric Kammerer Engine 7 Jun 11th, 05 06:08 PM
Offset for front wheels rcatalano Wheels & Tires 9 May 21st, 05 06:31 PM
