68 Camaro rear wheel and tire question. - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 31st, 07, 09:34 AM Thread Starter
Looking to upgrade to some MT ET streets on my current setup. I now have 8" wheels with 275/60/15 on the back with no problems. Would like to go to a 15" x 10" wheel and was wondering what is the biggest tire that can fit on the back without rubbing or having to cut it up to fit. I'm no expert on measuring back spacing, but was wondering if a 295 or even 315 would fit back there. If so, any idea on the back spacing I would need? Thanks
bb489 is offline
post #2 of 8 (permalink) Old Feb 1st, 07, 10:37 AM
Re: 68 Camaro rear wheel and tire question.
Your best bet is a 15x10 with a 5.5" backspace, and maybe that 295 will work out okay.
Jon
Driverz Inc.com
"The Custom Wheel Experts"
1-866-694-5940
68Jon is offline
post #3 of 8 (permalink) Old Feb 1st, 07, 03:32 PM
I'm running 15x8's w/ 4.5" bs and 285/60/15 SH (sh=short) McCreay's and they rub on off camber bumps (driveways/speed bumps).
I don't see a wider tire fitting due to the sidewall bulge. If you use a 5.5"bs wheel then the sidewalls need to be flat. If I measure from the wheel mounting surface to the inner wheel well I get 6"(using straight edge).
http://i10.photobucket.com/albums/a1.../28560s005.jpg
http://i10.photobucket.com/albums/a1...o/209e3e4e.jpg
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old Feb 1st, 07, 06:47 PM Thread Starter
What about a 15 x 8 with 4" backspace for the 295/50/15?
bb489 is offline
post #5 of 8 (permalink) Old Feb 2nd, 07, 12:48 PM
4"bs will stick out and hit the lip, maybe.
If you go with a 8.5-9" wheel it may work depending on tire bulge and 4.5-4.75 bs.
What I did to see what would fit was get all my measurments and put on cardboard,cut it out,and test fit at all angles.
post #6 of 8 (permalink) Old Feb 2nd, 07, 07:33 PM Thread Starter
Thanks for the replies. I have 275/60/15 on there right now and for some reason I have plenty of clearance all aound the wheel well and about 1" or more from the shock as it is now and very rarely rubs. The 295/50/15 are actually a little smaller in diameter I think than the 275/60/15 so I'm thinking that I should be ok. If the tires stick out a little more that is ok with me as long as it is not too far.
bb489 is offline
post #7 of 8 (permalink) Old Feb 3rd, 07, 03:47 PM
11.6 w x 26.6 t --> 295/50/15
10.8 w x 28 t ---> 275/60/15
Both are approx. due to Mfg. variances. Looks like it should work.
post #8 of 8 (permalink) Old Feb 5th, 07, 05:33 PM Thread Starter
Here is pics of the new 295/50/15 on my 8" Ralleye wheels with 4" bs. They fit without ANY mods and I have 1 1/2" from the inner tire well and plenty of room around the wheel well, plus they don't stick out that far at all! I think they look awesome. Now I am half tempted to put even fatter meats under there!
bb489 is offline
Wheel and tire combos for 68 Camaro SSCam427 Wheels & Tires 5 Mar 14th, 06 03:58 PM
Wheel question for 68 Camaro w/stock suspension pakmak Wheels & Tires 4 Jan 1st, 06 09:09 PM
Wheel and tire size for 68 Camaro - Please read 68SS96GS Wheels & Tires 10 Sep 11th, 05 08:15 PM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
