Thin Steel Shim Headgasket - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 3rd, 07, 05:48 AM Thread Starter
It's something I have never done with alloy heads is use the thin metal .015-.017 steel shim head gaskets. I have used them on steel heads only. I thought I even read where this was a no-no . I know they are not recommended for alloy blocks. Looks like I may attempt.
Has anyone had any issues them selves?
TC # 349
zdld17 is offline
post #2 of 5 (permalink) Old Feb 3rd, 07, 06:00 AM
Re: Thin Steel Shim Headgasket
stainless and aluminum dont mix. chemical reaction cause rot and they expand at different temps
chevy67 is offline
post #3 of 5 (permalink) Old Feb 3rd, 07, 06:10 AM Thread Starter
Working in the oil field, I have determined that, you are correct. And it don't make sense as the composition gasket indicated from GM, say they have the "stainless fire ring" around the bore opening.
These shim gaskets are steel and rubber coated which I coat with HiTack . I used to use alumin spray paint but seems the HiTack seals better. Thanks
TC # 349
zdld17 is offline
post #4 of 5 (permalink) Old Feb 3rd, 07, 07:36 AM
felpro 1094 on an undecked block with Canfield heads. Heads have been on 3 blocks now.
ZERO leakage or sealing problems
Felpro OK's them for iron/aluminum.
They are 0.015" thick
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #5 of 5 (permalink) Old Feb 3rd, 07, 10:05 AM Thread Starter
Thanks Tom, these are the varmits I have my eyes on. I am trying to juggle quench and compression on a 383. Pistons I have for choice are SRP 5 & 16 cc. I want 5 but numbers tell me 16 to run pump gas @ 9.9 with 64cc heads. I was planning on decking block to 0 but that make matters worse so if I leave 16cc piston .025 in hole and use .015 gasket, I am with desired quench and 9.9. . Going to 5 cc piston, I am still at 11.1 with .039 and if I use thicker gaskets, my quench goes to pot. So gues sit will be Felpro 1094 rubber coated with HiTack. I could of course special order piston but I would rather stick to off the shelf. Thanks again.
TC # 349
zdld17 is offline
.015 steel shim gaskets AH32 Performance 4 Oct 31st, 06 09:19 AM
Steel Shim Head Gaskets bowtie1Z28 Performance 7 Apr 20th, 03 05:04 PM
Refinishing Stainless Steel Indy Z11 Tech 2003 4 Apr 5th, 03 10:36 PM
Embossed steel shim head gaskets? Camaro6666 Engine 9 Mar 9th, 02 04:43 AM
composite vs. shim steel gasket Huck Engine 10 Oct 30th, 00 07:45 PM
