time mark - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 3rd, 07, 02:55 PM Thread Starter
time mark
hey i was wounderin if any knows whats wrong with this when i went to set the timing on my car the timing mark jumps around and always jumps to the same spots so i changed the timing chan but still does the same thing.
whitemike is offline
post #2 of 4 (permalink) Old Feb 3rd, 07, 03:27 PM
Re: time mark
bad gear on the dist...loose shaft bushings...broken adv springs...flaky vac signal at vac advance(i know you`re supposed to time the car with this disconnected)
kustomwerker is offline
post #3 of 4 (permalink) Old Feb 3rd, 07, 04:21 PM
Corky
Re: time mark
I'm assuming the timing is jumping around at idle? Does it smooth out as the rpm's come up?
I had that issue right after a rebuild so I knew it wasn't anything worn or loose. I had the lightest advance springs in the dizzy and with the engine idling at 950 - 1000 rpms, mechanical advance was starting to come in. I installed the next heavier springs and problem went away.
Also if you have a MSD or another multi spark unit, it can cause problems with some timing lights. Just a couple thoughts.
Corky
CorkyE is offline
post #4 of 4 (permalink) Old Feb 4th, 07, 12:41 PM
Re: time mark
A sticky oil pressure relief valve. Remove it and emery cloth the piston the a gloss. This solved my problem.
"Basics of Basics" Making Templates for cutting and drilling accuracy. MARTINSR Body Shop 3 May 13th, 10 07:06 PM
Hello...long time Camaro driver..first time here. OPUSONE Bench Racing 7 Mar 20th, 06 06:46 PM
Give back vacation time?????? BonzoHansen Bench Racing 21 Jan 7th, 06 12:14 PM
best new time 406sbc jethro81z28 Performance 6 Nov 19th, 03 02:52 AM
