350/330 crate engine cam upgrade - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 3rd, 07, 06:48 PM Thread Starter
I 'm thinking of changing the cam in my 350/330 crate engine, I would like to get around 375 -400 hp any ideas.
jdbr1 is offline
post #2 of 3 (permalink) Old Feb 4th, 07, 06:48 AM
Re: 350/330 crate engine cam upgrade
You are dealing with the newer block like the ZZ3 that I had. I went to the orginal ZZZ cam 10134334 with more duration. Ran better , would not lay down at 4800 . I believe the cam you have is 212/222 @ 435/460 lift.
The #334 is 235/235 @ 480/480 with the springs that came on the alloy L98 heads. Had this motor in manual and AT car but with 2k stall converter with 3.73 gears. There are others .
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Feb 5th, 07, 08:54 AM
I have that same motor in my 69z28, with 4.10's and an m-22wr. If you want to go roller install the gm hot cam kit. Several of the magazines installed the comp cams xtreme energy 268 and said it was good for 375hp. I installed the lunati voodoo 268, with crane 10309-1 springs and am relly happy with it. I don't have any dyno numbers but it definately picked up power all across the board and still pulls 13" of vacum at 750rpm idle.
Dave69Z is offline
zz4 350 crate engine curt powell Engine 23 Apr 2nd, 09 08:18 PM
383 Engine Upgrade thedugan Engine 7 Feb 28th, 06 06:31 PM
Engine Mounts 327 to 350 crate engine Sixty-Seven rs Engine 3 May 12th, 05 04:01 PM
Rebuild my 350 engine or look for a Crate Motor? 69Tux Engine 1 Apr 8th, 05 11:53 AM
GM Crate engine.. rphtx Engine 8 Jul 13th, 03 12:04 PM
