Aluminum Heads - Proper Gasket - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 3rd, 07, 07:55 PM Thread Starter
Is there a specific type of gasket to use with aluminum heads and cast iron block (copper)? My question is in regard to any chemical reaction due to electrical current or dissimilar metals or both that could cause leaks.
Countryside_Cafe is offline
post #2 of 6 (permalink) Old Feb 3rd, 07, 08:05 PM
Bill
Re: Aluminum Heads - Proper Gasket
cc,
The dissimilar metals are not a problem as long as the proper coolant is used.
The head gaskets usually are specified by the cylinder head manufacturer. There are different types depending on the conditions the engine will see. There are the normal composition gaskets, copper, multilayer steel (MLS) and probably some others.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #3 of 6 (permalink) Old Feb 3rd, 07, 10:38 PM
Use a gasket with a pre-flattened steel wire ring.
Regular head gaskets for cast iron head & blocks will make an impression in aluminum and will require machining (milling/decking) when reassembling at a later date.
For example, BBC with alumi heads.. http://store.summitracing.com/partdetail.asp?part=FPP%2D1027&autoview=sku
Don't worry about electolysis.
BlackoutSteve is offline
post #4 of 6 (permalink) Old Feb 4th, 07, 06:52 AM
For example, BBC with alumi heads.. http://store.summitracing.com/partde...7&autoview=sku
Steve, are you saying the coated thin steel shim .015-.017 gasket is ok to use on alloy heads? I am using the GM graphite with flattened wire ring but look to increase compression.
TC # 349
zdld17 is offline
post #5 of 6 (permalink) Old Feb 4th, 07, 07:19 AM
Fel-pro has said it is OK to use their SB #1094, .015" thick, rubber coated steel shims with aluminum heads.
pdq67
post #6 of 6 (permalink) Old Feb 4th, 07, 09:15 AM
pdq67
Thanks again, Then It will be done.
TC # 349
zdld17 is offline
aluminum heads kleptopigdog Bench Racing 6 Sep 21st, 05 01:18 AM
Torque specs for 385 fast burn aluminum heads bjj Engine 0 Sep 15th, 05 12:33 PM
Pro-topline heads...other intake and gasket options travis Performance 5 Aug 26th, 03 11:13 PM
special care for aluminum heads? bilydean Performance 13 Jan 30th, 02 12:35 PM
