Hard to start - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 4th, 07, 08:11 AM Thread Starter
Hard to start
Have a 1969 with a 350. Points dist and Quadrajet 4 barrel. The longer it sits in the garage without starting, the harder it is to start. Whats the secret? Do I pump the accelerator rapid....pump it slow....hold it down when cranking...pump the accelerator before turning the key. I think I have tried it all and still do not have the right combination to getting this cold beast started. No electic choke by the way. Once it warms up it starts on the first revolution.
It is embarrassing to show the car off when it has not been started. I usually tell people to call first and sneak in the garage to get it started before they arrive.
Gary
gary.mcl1 is offline
post #2 of 5 (permalink) Old Feb 4th, 07, 11:18 AM
Re: Hard to start
i had that problem with a qjet in my truck...seems the screws in the bottom of the carb loostened up and allowed the fuel to drain out of it...it would do this if it sat for more than 1 day, but i`ve heard of the same prob worse than mine where it would bleed down faster...when it has sat for a while, take the air cleaner off and pump the carb by hand while looking down the throttle bores to see if the accelerator pump is working before you turn the car over...this will tell you if theres fuel in the carb...hope this helped...
kustomwerker is offline
post #3 of 5 (permalink) Old Feb 4th, 07, 12:07 PM
Re: Hard to start
Check kustom's suggestions. If fuel, and no choke plate, then yes, pump several times, 3-5 times, leave pedal closed or just off idle.
Once it starts, then high idle it for about two minutes, then it should run by itself. Stock set-up on Q-jet, I believe, is a divorced choke, meaning a coil mounted on the intake and linkage to the choke plate. Same linkage also set high idle cam to fast idle engine, 1300-1500 rpms.
Is set-up has electric choke, then it needs ign supplied voltage to run, not from the points supply wire.
post #4 of 5 (permalink) Old Feb 4th, 07, 07:19 PM
JohnZ's Avatar
Re: Hard to start
If you don't see fuel from the accelerator pump when it's been sitting for a few days, the float bowl is empty (probable leakage from the bowl plugs into the intake manifold); when you pull the oil dipstick, do you smell gas in the oil?
JohnZ
CRG
JohnZ is offline
post #5 of 5 (permalink) Old Feb 4th, 07, 08:45 PM
Bill
Re: Hard to start
Gary,
How long are you talking about it sitting ? A few days ? A few weeks ? The gas does evaporate out of the carrb after a while. If it sits a few weeks it is not at all unusual to have to crank it a while to get some gas up to the carb, then pump it a couple of times, maybe crank some more .... not at all out of the normal. You say it does not have an electric choke .... is it a divorced choke with the rod to the spring in the manifold ? Does it have a choke at all ? Is it working ? The choke should close completely when you first pump the gas to the floor when it is cold.
If it has the problem after sitting for just a few days, the primary or secondary well plugs in the bottom of the q-jet are probably leaking ... another common problem. Anyone that has done more than a couple of Q-jets should be able to fix it for you. Basically you take the carb apart, clean off the bottoms of the well plugs, stake them back in place with a small hammer and punch, then epoxy over them to hopefully solve the problem for good.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
Won't start in the mornings DangerAhead35 Troubleshooting 7 Apr 16th, 06 02:50 PM
no start...91 v6... bloocamaro Engine 0 Nov 10th, 05 02:01 PM
Hard start after sitting Littletommy Engine 7 Apr 23rd, 05 10:31 AM
Hard start gadzooks25 Troubleshooting 11 Jun 7th, 01 01:37 AM
engine hard to start Robesco Troubleshooting 4 May 22nd, 01 05:55 AM
