750 Holley vac -vs- double pump.....are the baseplates the same???? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 4th, 07, 10:25 AM Thread Starter
Found a guy that has a vac real cheap and I need a baseplate to make my DP a complete carb. Are they the same??? THanks!
dubs68camaro is offline
post #2 of 3 (permalink) Old Feb 4th, 07, 11:59 AM
Re: 750 Holley vac -vs- double pump.....are the baseplates the same????
If my memory serves me right, the VC base plate does not have the rear pump arm pivot stud. The boss may be there and can be drilled to add that stud.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Feb 4th, 07, 01:40 PM Thread Starter
You are right Don....did some more searching and found that out.
Oil Pump Info High Volume Myths & Fables Set Straight camaroman7d Engine 21 Apr 16th, 04 03:54 PM
Holley Fuel pump paulm Performance 2 Apr 13th, 03 05:45 AM
Holley fuel pump? CamaroJSU Performance 7 Apr 9th, 03 06:26 PM
Holley carb pump cams caribbean camaro Performance 10 Oct 25th, 01 07:45 AM
Motor mount clearance with Holley mechanical pump ryskey67 Tech 2000 6 May 29th, 01 02:40 PM
