Building an LT-4 383 Stroker from an LT-1 - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 5th, 07, 12:10 AM Thread Starter
Question Building an LT-4 383 Stroker from an LT-1
I am in the process of building my LT-1 into a 383 Stroker LT-4. I want to get the AFR LT-4 heads for it but don't know which ones to get. There are about 4 different types: 215 cc LT-1 and LT-4 Raised Runner Aluminum Heads, 227cc SBC LT-4 Aluminum Heads, 220cc SBC LT-4 Aluminum Heads, 210cc SBC LT-4 Aluminum Heads, and the 195cc SBC LT-4 Aluminum Heads. Also, what size Cam Shaft should I get to gain maximum horsepower on regular pump gas and the type of pistons etc. Actually, the best process in building my engine.
Thank you
'95 Camaro Z-28
Rokbrigade is offline
post #2 of 5 (permalink) Old Feb 5th, 07, 08:04 AM
Re: Building an LT-4 383 Stroker from an LT-1
I don't know what the LT means in the designations but are you just building a 383 from a crate motor ? The only thing I see first off is the newer blocks have the spider plate retainer bar that locks the GM roller lifter in position. This is an inexpensive way to start . All you have to do is get a cam to match your combo. As for piston, you need to determine what application you want to run, street , race , etc. As for heads, I think you need to stay between the 195 cc - 210 range, depending on your piston and application of this motor. I have the 195's on my mule 355 and they will be ported and put on a street 383. I do intend to run my current XR 282 retro roller as I don't have a late model block . I do believe you need to stay in the 10 scr or slightly under such as 9.9-9.5 range to run pump prem fuel. There is a bunch of stroker kits out there, you just have to make your mind up on which one. You prolly have visited AFR's site and get flow numbers off the LT 4 heads. I dont think they vary much from the 195 ported.
TC # 349
zdld17 is offline
post #3 of 5 (permalink) Old Feb 5th, 07, 08:49 AM
DjD
DjD's Avatar
Don - the LT1/LT4 is the designation given to the early to mid 90's 350 with alum heads and opti spark (crank trigger) ignition. Used in vettes and '93-'97 Camaros before the LS1 was introduced. The LT4 was used in Camaros in '97 and only a few handfulls were produced.
...Dennis
DjD is offline
post #4 of 5 (permalink) Old Feb 5th, 07, 09:19 AM
Thanks Dennis, then I a wet here but I think I still am close when I mention the spider bar? To guide the roller lifters. Prolly pretty much L98 motor I guess.
TC # 349
zdld17 is offline
post #5 of 5 (permalink) Old Feb 5th, 07, 01:38 PM
the LT1 and LT4 engines were the final evolution of the "old school" small block. reverse cooling, front mounted distributor, cam driven water pump. the LT1 was used in 92-96 Corvettes, 93-97 f bodies, and 94-96 B bodies. the 94-96 Caprice also had a 4.3 liter version in 94-96 Caprices only. it had the bore of a 305 with a 3" stroke crankshaft and longer 5.94 con rods.
once you strip one down, they look a lot like any other 87 and newer small block, but with a different timing cover, water pump, and cylinder heads with different cooling passages.
the LT4 was the ultimate version of the LT family- it had bigger heads than the LT1, and a bigger roller cam with 1.6 roller rockers. it was the ONLY small block to ever come from GM in a car with roller rocker arms. i think it had 210cc intake ports stock, so they were pretty generously sized.
you don't plan sincerity.
novaderrik is offline
Building BBC ti69ss Performance 2 Dec 28th, 06 09:30 AM
Insulating A Metal Building?? camaroman7d Bench Racing 35 Dec 15th, 06 02:42 PM
Help building a huffer motor.... 496z/28 Performance 12 Apr 19th, 06 06:12 AM
Roots Blower theory for building BBC dragon0123 Performance 16 Dec 24th, 05 05:01 PM
Building an Engine CRUZ'in68 Tech 2000 4 Nov 4th, 00 12:54 AM
