92 Camaro 3.1L Camshaft Pull in Car?? - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 5th, 07, 09:33 AM Thread Starter
Larry
Is it possible to pull and replace the camshaft without doing an engine pull.???? Would it also be possible to change the camshaft bearings without pulling the engine and if so, how????
LarryD is offline
post #2 of 4 (permalink) Old Feb 6th, 07, 06:59 AM Thread Starter
Larry
Re: 92 Camaro 3.1L Camshaft Pull in Car??
The answer is YES for the camshaft.. Gave up and just did it last night....
LarryD is offline
post #3 of 4 (permalink) Old Feb 6th, 07, 07:14 AM
Cool! Now, what are you going to install?
post #4 of 4 (permalink) Old Feb 6th, 07, 10:56 AM Thread Starter
Larry
Will probably just replace the camshaft and maybe the front cam bearing, timing chain (as long as I am there), and the lifters.. When I did a compression check I had 138 to 145 in 4 of the cylinders and 122 to 125 in the other two... Going to pressure test them again tonight to see if they hold pressure just to make sure about the valves and rings...
LarryD is offline
Car Wrecks Into My House and Camaro (Long,Pics) erik67ssrs Bench Racing 34 Jan 21st, 07 04:45 PM
OK Fella's....here it is! 2009 Camaro. Infamous Fifth Generation 195 Sep 8th, 06 07:10 PM
Non Camaro, but a great story ProdigyCustoms Bench Racing 3 Aug 2nd, 06 09:40 AM
Best Way to Locate a 69? camaromaniac Camaro Tech 16 Jan 11th, 06 09:10 PM
more readings I found on up-coming camaro JFINN1976 Bench Racing 2 Oct 23rd, 04 08:37 AM
