timing too low??? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 5th, 07, 11:52 AM Thread Starter
timing too low???
My 350 dies when you put it in gear(automatic) it idles at 1100, it has a large hyd flat tappet cam 525 lift 110 lobe seperation 305 duration. A converter stall of 4000. The timing is at 14 deg. inital on tdc should it be at btdc? Is tdc my problem?
gregvega is offline
post #2 of 2 (permalink) Old Feb 5th, 07, 01:42 PM
Re: timing too low???
timing is set at tdc.
that is a pretty healthy cam, and getting something like that to idle decent can be a chore. timing and carb adjustment need to be right on.
i'd try hooking the vacuum advance up to manifold vacuum and turning the idle speed down a bit to get started.
you don't plan sincerity.
novaderrik is offline
Octane for 69 Z28 camarozbest Camaro Tech 13 Jul 2nd, 07 09:40 PM
Small jets but still seems rich. camaro_fever68 Performance 10 May 24th, 06 05:46 AM
Vacuum advance questions..? PairOf69's Engine 6 Dec 28th, 05 10:29 AM
Backing out low end timing for more TQ? Eric68 Performance 22 Jul 10th, 05 11:37 AM
getting too hot noels69 Heating & Cooling 14 May 31st, 05 08:53 PM
