machanical fuel pump - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 5th, 07, 05:33 PM Thread Starter
Dan
I am looking for someone that has used a carter 170gph machanical fuel pump
I'm getting ready to redo my fuel system and I was woundering if the carter 170 gph machanical fuel pump has any fitment problems in a 69 camaro with a 350 sbc.The carter 170gph pump looks very large in size.does this pump hit the chassis? or any other problems!!
__________________________________________________ __
Dan
69 coupe, 350 crate motor/Th350c trans with 2.75 low first gear--2500 lock-up converter
Not a show car, just a part time Driver!!!
pappy's69 is offline
post #2 of 5 (permalink) Old Feb 5th, 07, 06:18 PM
luke
Re: machanical fuel pump
i've got a holley 170 gph in my 69 with a big block. i don't know about the carters but on my holley the bottom half can be unscrewed and rotated to point the inlet and outlet whatever direction you want. i'd imagine you won't have any problems with one on a small block.
lukeciffer is offline
post #3 of 5 (permalink) Old Feb 7th, 07, 12:16 PM
Mel
I'm using a Carter mechanical pump, it has female 1/4" NPT outlets in which you need to use a male 1/4" NPT to 3/8" or universal nipple for the rubber line on the inlet side and the same for the outlet side, (unless, like me,you run a 3/8" hard line then you need a 1/4" NPT to a 3/8" Inverted flare. You can bend the line yourself and flare it, aluminum is easier to work with than steel).
But the Carter also allows you to unscrew the bottom to rotate the bottom of the housing and point the outlets where needed for correct alignment with fuel lines and no fitment problems with chasis. Provides about 6-8 psi.
Mel
69 Z28, DZ, M20, BU.
melav8r is offline
post #4 of 5 (permalink) Old Feb 7th, 07, 01:36 PM
Sean
I am running a Barry Grant superspeedway mech., which is pretty much the exact same thing, and it has plenty of room all around. Even using larger -8 An fittings.
Ditto on the abilty to "clock" the bottom of the pump to suit your needs with the BG.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 5 (permalink) Old Feb 7th, 07, 06:12 PM
Tried one here and the lower clockable half was still too large , as the lower half hit the frame. Went to Edlebrock with a smaller id lower clockable half and cleared . Be careful using hi psi pumps with out going to brass tipped push rods. After a few hundred miles, I had to go carter electric as my fuel pump lobe said goodbye on my hydra roller.
TC # 349
zdld17 is offline
The "Run to the Rockies" is on the way! JimM Bench Racing 119 Aug 15th, 06 10:55 AM
Fuel pump noise Hot 67 Performance 2 Jul 10th, 06 08:38 PM
Fuel Pump lobe on Roller Cams zdld17 Performance 17 May 23rd, 06 07:08 PM
dumb question about clocking Mech Fuel Pump Brad74 Engine 6 Mar 21st, 06 08:10 PM
Running with the stock intank fuel pump... RegaMaro Performance 0 Mar 8th, 06 10:25 PM
