Re: Q-jet vacuum fittings
PVC is obvious, the 7/32" nipple.
Vac advance comes from the upper nipple on front of the carb, and connects to a solid tubing, in its bracket held in place by an intake bolt, to about 4 inches from the cannister, then its a length of hose.
The air cleaner air door is from the nipple on the passenger side.
Choke pull-off nipple points to the carb nipple, short length of hose.
All other accessories, A/T modulator, A/C, & P/B, come of a fitting on the rear of the intake.
