Cam Selection Help - Team Camaro Tech
post #1 of 16 (permalink) Old Feb 6th, 07, 05:52 PM Thread Starter
Cam Selection Help
Hi:
Need some help selecting a cam for my engine re-build.
What I have:
350 CI 0.060 over
10.5:1 pistons
Dart SS Iron heads 2.02/1.60
Edlebrock air gap manifold
4-Speed
4:11 axle ratio
manual brakes
1 5/8 primary tube headers
Car is driven on Saturday nights...
I was thinking of the old 30-30 cam remake from Comp Cams or their 294 series solid lifter.
Thoughts?
Cardfan16 is offline
post #2 of 16 (permalink) Old Feb 6th, 07, 06:18 PM
Re: Cam Selection Help
How bout something in the H268 range. This is a good all round workhorse cam. Don't have a lot of overlap.
TC # 349
zdld17 is offline
post #3 of 16 (permalink) Old Feb 6th, 07, 07:15 PM
Harley
wiskeesour's Avatar
Talking Re: Cam Selection Help
I second that, however, Same motor with a XM274 from Comp was ALOT of fun!
AE2(AW) Harley Moody, USNavy
Thanks Chief.
wiskeesour is offline
post #4 of 16 (permalink) Old Feb 6th, 07, 08:09 PM
Thumbs up Re: Cam Selection Help
You want a mild Thumper then please consider either the old Isky Z-25 or Z-27 solid cams!! HECK, I will also say the Z-30 too, even tho you are below 11 to 1!!
Sucker should run AND rpm GREAT with any of them!!!!!!! Smaller, more grunt, bigger more top-end sorta deal.......
You got the reg and the compression so use it..
pdq67
PS., and I do figure in a 360" SB, the old GM 30-30 solid cam will do fine at 10.5 to 1 vs 11 to 1 CR. in the smaller 327's due to it's longer stroke....................
post #5 of 16 (permalink) Old Feb 7th, 07, 07:51 AM
Aaron
i agree with pdq...
with your compression, you'll want a tad more overlap.
the 30-30 is a great choice, and still hard to beat.
A
69z28boy is offline
post #6 of 16 (permalink) Old Feb 7th, 07, 08:18 AM
Originally Posted by 69z28boy View Post
i agree with pdq...
A
Why would he want more overlap? What does that have to do with the compression?
onovakind67 is offline
post #7 of 16 (permalink) Old Feb 7th, 07, 12:31 PM
Wes
I like my old-school brethren touting the old stuff! Yeah, the 30-30 would rip with your 4.11's and 4-speed.
Or, Comp's 280H if you're in to flat-tap hydraulic. The 268H is great but may ping some with your 10.5:1 CR.
No secret, with headers, good heads, and good flowing exhaust, I like a good single pattern cam.
My opinion,..worth what you paid.
Straight-line-69 is offline
post #8 of 16 (permalink) Old Feb 7th, 07, 01:01 PM
Comp XS282S.
67 Bassman is offline
post #9 of 16 (permalink) Old Feb 7th, 07, 03:44 PM
Aaron
if he doesn't want too run 110 octane all the time,
the additional overlap of the 30-30 (as compared to a smaller camshaft will bleed off some compression.
plus he has the gearing and tranny to run the 30-30 properly.
the new cams with faster ramps have less seat to seat duration, and thus have less overlap... resulting in higher cylendar pressure and higher octane requirement.
so a small modern cam might make a ton of torque, but he'll blow the tires off the car and have to keep race fuel in the tank... hardly a street car.
thats what I was getting at.
69z28boy is offline
post #10 of 16 (permalink) Old Feb 7th, 07, 05:09 PM
What I'm getting at is that overlap has nothing to do with compression. The overlap period occurs at the end of the exhaust stroke. The event that controls cylinder pressure is the intake closing point.
I wouldn't worry too much about blowing the tires off with a mild 355" motor, you won't get the torque multiplication with the 4-speed you get with an automatic. For a good street car you want 'a ton of torque', fumbling around trying to find some horsepower in the rpm range you spend most of your time in isn't productive.
If you take your time and do things right you can run quite a bit of compression using 91-92 octane pump gas. We have a 10.8:1 331" small block street car with a 'modern' 240°/240° cam in it that runs very well on California 91 octane. I have a 10.3:1 406 daily driver with a 224°/224° cam that runs on the same gas.
post #11 of 16 (permalink) Old Feb 7th, 07, 10:27 PM
Aaron
yes... my point was simply that a larger cam, especially an old school cam with slower ramps will bleed of compression and allow use of lower octane..
i had an old Comp Hyd 292h in a 350 that was 11 to 1... it would ping on anything but a mixture of race gas..... i went to a 30-30 solid and it ran everybit as good, but could run all day on Sunoco 94 (unless i floored it in 4th gear at about 15 mph) LOL
69z28boy is offline
post #12 of 16 (permalink) Old Feb 8th, 07, 05:37 AM Thread Starter
Thanks to everyone for the input.
I am leaning towards the 30-30. Silly question... does anyone have any information on the new Comp Cams "thumpr" series??? Just curious.
post #13 of 16 (permalink) Old Feb 8th, 07, 07:18 AM
post #14 of 16 (permalink) Old Feb 8th, 07, 08:05 AM
There was recently a VERY long post on Team Chevelle regarding the thumper series
post #15 of 16 (permalink) Old Feb 8th, 07, 05:41 PM
Walter
I have the 401A6Lun in my 9.5-1 350. It is ground on 112lsa, and runs like a scalded dog with the 180cc AFR's on there. Real fun to see the jaws drop on my mustang victims in my heavy short bed truck. LOL...
Solid; Fair idle. Excellent Pro Street cam for 355–400 cubic inch motors. Needs 2500–3000 RPM stall converter, headers, 10:1 compression ratio, and 3.73 or better gearing.
Advertised Duration IN/EX: 276/284
Duration @.050 IN/EX: 243/251
Gross Valve Lift IN/EX: .518"/.530"
Lobe Sep Angle / Intake Ctr Line: 110/104
Valve Lash IN/EX: .026"/.026"
RPM Range: 2500-6800
wildman926 is offline
Help with cam selection 406 jcdubs Performance 17 Jun 5th, 06 06:39 AM
overlap, and stock idle L79Mike Performance 13 Jan 21st, 06 10:23 PM
Lobe Separation Angle questions 69ProTouring Performance 19 Oct 10th, 05 06:41 PM
Cam selection for original SS 350 68SSCamaroinKS Engine 9 Sep 11th, 04 04:17 PM
cam selection Dysart316 Engine 4 Mar 29th, 03 05:30 PM
