454 already balanced and now adding new clutch and pressure plate...still balanced??? - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 7th, 07, 11:53 AM Thread Starter
Had a 454 balanced internally, then balanced with the flywheel and dampener (not sure what order...maybe all at the same time). Will adding a new clutch and pressure plate be close enough or will I run into problems?? I'm sure in a perfect world, You may want to do everything, but "I'ze aint pullen de moter apart no mow"!!!!
dubs68camaro is offline
post #2 of 3 (permalink) Old Feb 7th, 07, 12:24 PM
Wes
Re: 454 already balanced and now adding new clutch and pressure plate...still balance
You should have no problems. Most clutches are balanced at the factory and you may can see some balancing weights on the pressure plate.
Internally balanced 454,..good call!
Straight-line-69 is offline
post #3 of 3 (permalink) Old Feb 7th, 07, 05:58 PM
i agree...even having the flywheel turned wouldnt throw it out of balance, as there is an equal amount of material removed from the friction surface...
kustomwerker is offline
