frame mounts for v8 swap - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 7th, 07, 05:39 PM Thread Starter
Hi, I am fixing to put a 350 4spd in my 6cyl convertible, I bought new motor mounts today and for some reason I was thinking they would work with the 6 cyl frame mounts, they don't. I am also assuming my original Z bar would work, am I wrong again? Should I just buy repo frame mounts or is finding some originals going to work better? Thanks
67rs4spd is offline
post #2 of 6 (permalink) Old Feb 7th, 07, 05:50 PM
Re: frame mounts for v8 swap
This topic keeps coming up. At some point, someone is going to give you some great links that go into detail on just what you need to know. I can't remember who it was, but I found out I had SBC mounts under my 396. The motor sat crooked.
dubs68camaro is offline
post #3 of 6 (permalink) Old Feb 7th, 07, 06:23 PM
Jon
Rodder's Avatar
Send a message via AIM to Rodder Send a message via Yahoo to Rodder
6cyl used different frame brackets.
http://www.camaros.org/engine.shtml#EngineMounting
Did you buy "short and wide" engine mounts? If so, you want the 67-68 smallblock frame brackets. If you got the "tall and wide" mounts, you want the 69 302/350 brackets.
Rodder is offline
post #4 of 6 (permalink) Old Feb 8th, 07, 10:46 PM
Strick
Can someone who has done this please link the poster (and I) to a supplier where the order can be placed easily? I will be doing the same thing (except no 4 speed) within the next month or so. If I have the right #'s I would just order them now.
Thanks!
Strick
Strick is offline
post #5 of 6 (permalink) Old Feb 8th, 07, 11:26 PM
A small block Z-bar is 9 inches long. I never measured a 6 cyl Z-bar, so I don't know if they are same.
Regarding the style of motor mount you bought and the style of frame stand you need, you can see pics of the different styles on David Pozzi's site.
http://www.pozziracing.com/camaro_engine.htm
Eric
Eric Kammerer is offline
post #6 of 6 (permalink) Old Feb 8th, 07, 11:29 PM
Strick
For some reason, I can't get on Pozzi's site. I tried earlier also.
Thanks for the link though.
Strick
Strick is offline
Need help with correct engine mounts (towers off frame) for '68 BBC dubs68camaro Engine 10 Jan 21st, 07 01:29 PM
1969 Z28 engine frame mounts??? tyrfryrtom Tag Team 2 Nov 28th, 06 11:07 PM
frame to body mounts - repair/replace inetquestion Restoration Corner 2 Oct 21st, 06 10:10 PM
searching for frame mounts bmann2 Engine 2 Oct 24th, 01 05:46 AM
Big Block Frame Mounts cardude Engine 2 Dec 3rd, 99 07:17 PM
